turn signals dont work?
so i got a new battery put in and an idle control valve. i got my car back from the shop and the turn signals dont work. however, the same lights are the ones that light up when you lock and unlock the car and the hazards. so the bulbs work and all, just not the turn signals. anyone know what i can do to get them working? Thanks.
My Ride: 2007 e60/black sapphire metallic/auburn leather/heated front seats and steering wheel/premium package/premium sound package/sport package/shadow line trim/6 disc in dash/multi-contour front seats/sport suspension/comfort access/moon roof/ rear all around sun shades/park distance control front and back/adaptive xenon headlights/ navigation/ Aerodynamic kit/ carbon fiber roundels hood trunk and steering wheel/ 35% tint all around + visor/ racing dash license plate lights/ matte black grille/ invisabulb turn signals/ charcoal filter delete/ euro stickers/ weisslicht LED side markers
i have the same problem. Im taking it to BMW to get my harness changed (its a common e60 problem)
If the signals were working properly before your car was serviced and they aren't now ... why should you even be concerned with warranty? I'm sure you used a turn signal within a few hundred feet of leaving the dealer and drove back immediately and said, "What gives?"!!
Engine: N54
The turn signals a single wire connected to the light module. The light module then sends a K_Can message to turn the turn signals on on and off. The instrument cluster is 'dumb' and simply listens for the K_Can message.
If the signals are not working then either the number 6 wire on the steering column switch is loose or the x1880 connector is loose. I'd wiggle the wires near x1880; it's located near the turn stalk, it's an 8 pin connector, and pin 5 and pin 8 are not used...
socale39
09-05-2023 08:30 AM
Awest91
09-17-2022 11:05 PM
