5Series.net - Forums
-   -   Try my Logic7 EQ settings (https://5series.net/forums/e60-discussion-2/try-my-logic7-eq-settings-18842/)
pitpro Nov 21, 2005 01:51 PM
Try my Logic7 EQ settings.
Tell me what you think. Comments?
All settings are the number of bars from the complete bottom of
equalizer(not middle neutral)
7 6 7 3 5 9 9
I listen to mostly FM.
These settings sound great to me.
znod Nov 21, 2005 03:28 PM
Thanks. I might give them a try.
tachyon Nov 21, 2005 03:48 PM
cool. and how do you set the bass and treb?
pitpro Nov 21, 2005 04:07 PM
Treble/Bass both neutral
Balance 2 ticks to passenger side
Fader 4 ticks to rear
Don Juan Nov 21, 2005 06:16 PM
ummm what the heck, nothing better to do..going to the garage now :P
ummm not bad, i like them..I set the Logic7 on concert mode...thanks :thumbsup:
Bambi Nov 21, 2005 09:47 PM
I think I'm the laziest guy here. I set everything all the way to the top in concert mode. And I think I've got a very very rich sound. :P
heezy545i Nov 22, 2005 12:31 AM
What type of music do you listen to?
ats77 Nov 22, 2005 02:18 AM
Bambi UR a wolf not a bambi
come on you put da bass up to TOP??? then your system must BANG on the windows
I will try the settings ,and used until now the settings from Iceman TM.. he set as a V shape...
subterFUSE Nov 22, 2005 06:15 AM
7 6 7 3 5 9 9
It won't do anyone much good to use your EQ settings. EQ settings are dependant upon the source material. FM radio, for example, is typically EQ'd with excessive amounts of bass before it gets to your car. A professionally mastered CD will sound very different. It will most likely have been compressed/limited.
Every source is different, and would theoretically require different EQ settings.
I think a really nice feature addition to the Logic 7 stereo would be EQ presets that can be saved and recalled. That way you could set one EQ curve for radio, one for Sirius, one for CD, and one for your iPod.
Even then, when you change CDs the EQ settings would technically need tweaking, because no two CDs are mastered the same.... but at least you could keep them somewhat in the area you want.
pitpro Nov 22, 2005 06:37 AM
7 6 7 3 5 9 9
Yea, Yea, I know all that, I have read all the threads, and I agree. I have always opted for the best factory sound system in my BMW's and up till now they have always had 3 or 4 memory settings for the EQ. Leaving this out was a mistake for BMW and they should fix it in a software revision.
But with the current state of affairs they have to be set SOMEWHERE.
Like I said, try them and let me know what you think. (one thing I noticed is that distortion is limited with this setting, music sounds clean and natural, yet spatial)
