Trunk won’t open (electronically)
When I hold the trunk release switch on the trunk lid, I can here an intermittent buzz from the latch. Sounds like a busy-signal, but very faint. I took a sound clip of it:
The latch is mechanical and when tripped to latch, there is a hook that holds it closed. The solenoid pulls the latch and the opening is done with a spring. My money's on no power to the solenoid (but it could be a bad solenoid (rare)).
the trunk won't open nor close. .
No idea. Maybe if the OP pulls the latch off we can see. I'm not going to pull my functioning one apart just to see. That said, if the latch relied on power being applied to close, would it also need power to stay closed? Sounds sketchy to me.
Broken wires at hinging area.
Soldered back together, heat shrinked.
Others had cracks in insulation so I liquid electrical taped them before they could cause problems in the future.
Bingo. And the brown wire is the main power line.
