trunk won't open with comfort access
Old 07-18-2012, 08:08 PM
tpaxadpom's Avatar
My Ride: E60 550i
Model Year: 2010
I recently purchased 2009 550i for my wife. The trunk won't open if I press "trunk open" button on the remote. The car has comfort access option. I just replaced the battery as it was low but nothing changed. I managed to get it to open a few times by pressing unlock button and then trunk open button but the results are inconsistent. According to the manual one has to press the button and hold it for 1 sec. When I do this my turn lights start to flash. If I hold it for ~3s (as per manual) the car goes into panic mode. I have locked and unlocked the trunk with the key. I have no problem opening the trunk manually or using the button inside the cabin. Any idea what's going on?
On another topic, I only have 1 comfort access fob. Is it possible to order non-comfort access key fob that will require no programming?
Old 07-19-2012, 06:59 AM
NoQuarter's Avatar
Engine: N54
Mine is a "2-click" sort of process. Try this: press button for ~1sec and release then press it again right away.
Old 07-19-2012, 07:21 AM
Gilgorm's Avatar
My Ride: 2012 535i X-driveSpace Grey/Black Dakota, Fineline Anthracite Trim; Executive Package (Rear View, Lumbar, Nav, Voice, SIRIUS, HiFi Pro) Technology Package (Hi Beam Assist, Lane Departure, Blind Spot Detection, Surround View) BMW Apps (Apps, Smart Pho
Model Year: 2012
+1 Two click method worked for me too. Hold too long and the alarms go off.
Old 07-19-2012, 10:30 AM
e60frankdatank's Avatar
My Ride: 08 535i
this happends to me also, i always need up opening it by hand. I will try this method
Old 07-19-2012, 03:54 PM
My Ride: 08 535i
i tried it and it works. thanks now i know how to use mu remote trunk opener lol
Old 07-19-2012, 08:31 PM
tpaxadpom's Avatar
My Ride: E60 550i
Model Year: 2010
NoQuarter, much appreciated. This combination works on my car. I wonder why manual doesn't mention this...
Old 07-20-2012, 07:14 AM
NoQuarter's Avatar
Engine: N54
I'm thinking it is a change to help against the accidental opening from the keys in the pocket problem. It is harder to get the right double-click process in the pocket than a single press.
Old 07-20-2012, 11:39 AM
Gilgorm's Avatar
Model Year: 2012
Just to clarify, my E60 would often work with just one push but the alarm would go off half the time so I went to the two click approach with no problems.
BTW, my new F10 has a separate button for the trunk and a separate button for the panic alarm.
Old 07-20-2012, 04:08 PM
tpaxadpom's Avatar
My Ride: E60 550i
Model Year: 2010
The reason for double-click is obvious. What is not obvious is why this change to $70k car doesn't have any instructions in the owners manual.
dmahon
12-08-2020 09:53 PM
milkox
07-15-2015 09:48 AM
525d MSport
F10 Discussion
07-12-2015 07:03 AM
Bigcar78
07-09-2015 09:58 AM
SSRL_2006
07-07-2015 10:18 AM
Quick Reply: trunk won't open with comfort access
