Trunk Fuse Box Swap [Question]
Old Jul 29, 2015 | 02:35 PM
e60_simr's Avatar
My Ride: 2005 BMW 525i
Default Trunk Fuse Box Swap [Question]
I have a 2005 BMW 525i. It's new-to-me and already I've discovered quite a few things that need repair.
First and foremost, the fuse box in the trunk had a slot that had been stretched out and the fuse was unable to make the connection. Specifically, slot #63. After a bit of googling, I decided instead of doing what the previous owner most likely did, wrap metal around the fuse to guarantee a tight fit... I ordered a brand new fuse box (the whole unit!).
So I figured it would be a straight swap but just in case I called up the dealership and the guy there informed me that there is a chip inside the fuse box that would require them to do the swap. I can provide the replacement fuse box but they'd charge as much as they do ($$$) for labor.
First, I didn't believe him; dumb move. I went ahead with the plug and play swap. Result: Electronics work but car doesn't start. No engine turning sound and quite a bit of error lights. Panicked, I quickly replaced the replacement fuse box with the original. Car started!
So my question is: anyone know how to swap the fuse box or what specifically inside the fuse box causes it not be such an easy swap? As a last resort, I'll obviously go to the stealership but I figured it would be a good idea to be a bit more educated about it all first.
Thank you for your time.
squints2c
Oct 6, 2022 03:33 PM
windnsea
May 25, 2015 09:49 PM
Stranger12
Apr 12, 2015 02:07 PM
kennethnoel
Apr 7, 2015 06:17 AM
zippers525
Apr 26, 2004 06:53 PM
