Trunk
My Ride: 05 530 Jet Black, Black Int., Nav, Sat, Comfort Seats, Xenon.
just picked up my 05 530 (jet black, nav/sat) and when I got home I realized my trunk does not open with the remote button. Any idea why this would happen? Programing?
Also, when I open the trunk, it opens very fast and requires a lot of pressure to close. Does it need adjustment, is this normal?
Thanks
gary
Thanks
gary
My Ride: 2001 BMW330ci, Steel Gray, Black leather, Steptronic, PP, SP, PDC, Heated seats, Xenon head lights, HK, 6 disk changer, OEM alarm, OEM clears,Iice white fog lights ,Universal trasnciver, 17 inch Michelin Pilot Sport Tires
2005 530i Titanium Gray,Black leather, Nav.,HUD,PP,CWP,SP,PDC,Xenon lights,Steptronic,Logic 7 sound system,,Fold down read seats,Power shades
ON ORDER
[quote name='genaman' date='Feb 27 2005, 12:13 PM']
Thanks
gary
If you lock the car with the remote and then press the trunk button it will open for you.
Its normal that it opens up fast and needs alot of pressure to close.
vern
PS I felt the same way when I took delivery last week on my 530i
Enjoy
Thanks
gary
[snapback]94942[/snapback]
[/quoteIf you lock the car with the remote and then press the trunk button it will open for you.
vern
Enjoy
This sounds normal. To open the trunk, just press the button under the trunk lid, and step back. The trunk lid will come up pretty quickly, but after you've gotten used to it, it is a very nice feature. You don't have to use an extra hand to raise the lid because the hydraulic cartridges have worn (a problem I've had on every other car I've owned). To close, you do need to slam it pretty forcefully, but I've gotten used to it. Now that I'm used to it, it's not a problem.
There is a technique to opening the trunk with the remote. It is not an instant release as it was with the E39. Hold for a "one thousand and one" count and release. That should do it. If you hold it too much longer, the remote will activate the alarm system which can easily be silenced with any button on the remote.
My Ride: G30 M550i
Model Year: 2018
The trunk should open with the remote (on the key) whether or not the car is locked.
There's an art to getting the remote to open the trunk. You have to press and hold it for about a second (count "one one-thousand") and it should open. In the US, if you hold the button down too long, you'll set off the panic feature of the alarm system. (You can search the forum with the word "panic" and you'll probably come up with the details.)
One thing I've been wondering about lately is whether or not BMW adjusted the sensitivity of the panic alarm threshold. Since my latest software upgrade (13.2), I haven't set off the panic. It could be that they fixed the timing or it could be that I'm just "programmed" to press it just right.
Banned
Originally Posted by Rudy' date='Feb 27 2005, 09:39 AM
There's an art to getting the remote to open the trunk.? You have to press and hold it for about a second (count "one one-thousand") and it should open.? In the US, if you hold the button down too long, you'll set off the panic feature of the alarm system.
[snapback]94952[/snapback]
Originally Posted by genaman' date='Feb 27 2005, 01:13 PM
just picked up my 05 530 (jet black, nav/sat)? and when I got home I realized my trunk does not open with the remote button.? Any idea why this would happen?? Programing?
Also, when I open the trunk, it opens very fast and requires a lot of pressure to close.? Does it need adjustment, is this normal?
Thanks
gary
Thanks
gary
Originally Posted by Rudy' date='Feb 27 2005, 11:40 AM
JDN, you beat me -- is it me or has the newer software fixed the panic bug?
[snapback]94953[/snapback]
You might share with genaman your preferred trunk closing technique, so thoughtfully designed by the Germans.
Originally Posted by surgeon' date='Feb 27 2005, 10:10 AM
have 2005 530i for one week. Yes the trunk opens fast (keep face out of way) and needs alot of pressure to close, unlike my wifes 325i convertable
[snapback]94963[/snapback]
