Transmition toast??
Old Jul 25, 2015 | 04:52 PM
Maciek Michalak's Avatar
My Ride: E60 Stock
Default Transmition toast??
I have a 2004 530i with 120k on it. I was on my way to a buddy's lake house which was about 80 miles out. About 40 miles out after cruising about 80mph the whole way I get offrom the highway and stop at a red light. I try to go and boom nothing. No response from the transmition. RPMs go up but car won't move. I restart the car unplug the battery still nothing. Tried to push the car a little and drop it in drive thinking something just got stuck and still nothing.
After restarting the car when I put it in drive the trans jumps. Weirdly enough the car tries to drive in Neutral!!
What could be the issue??
Old Jul 25, 2015 | 05:11 PM
jfife83's Avatar
My Ride: 05 545i
Start by checking fluid level...if it's low auto trans can malfunction. ...
Old Jul 26, 2015 | 03:31 AM
V70Cat's Avatar
My Ride: 535XIT Space Gray, Cream Beige LeatherCold Weather, Premium, Auto, Rear Side Window Shapes, Heated Rear Seats, Park Distance, Navigation, Satellite Radio
Model Year: 08
Have it towed to a mechanic, BMW indy or BMW
Old Jul 26, 2015 | 04:22 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
check the DIY section of this forum. First thing you need to check is that your fluid level and condition are good, and that you have no leaks. You also need to have EGS read for fault codes.
Old Jul 29, 2015 | 06:36 AM
mowens's Avatar
My Ride: 2008 550i w/sport pkg & sport auto tranny; Beyern black mesh wheels, Dinan Level III suspension
Default Get to a mechanic and hook it up
A similar problem happened to me, but I was just pulling out of my neighborhood. I have an '08 550i with 114,000 miles and the Sport Auto trans. I was receiving a transmission error and dreading the expected cost. Had it towed to my mechanic. Turns out it was coil #3 had blown just as I accelerated. Replaced the coil, reprogrammed the car, and it's running great again. Hope you get as lucky!
Old Jul 29, 2015 | 03:06 PM
My Ride: E60 Stock
Default Update
Ok I took it to the mechanic and he told my my oil pump was not working and I blew it. He quoted me $2400 out the door to rebuild it. Does that sound like a good price? Also I could buy a used transmition somewhere and get it installed for $450 plus $150 for oil. In that case any recommendations on where I could get one?
Old Jul 29, 2015 | 07:25 PM
twh's Avatar
twh
My Ride: 2006 BMW 530xi 6MT
Engine: N52
If you are in the $2400 range, I'd look at prices of factory rebuilt transmissions.
Old Jul 31, 2015 | 07:48 AM
txag_530i's Avatar
Ok I took it to the mechanic and he told my my oil pump was not working and I blew it. He quoted me $2400 out the door to rebuild it. Does that sound like a good price? Also I could buy a used transmission somewhere and get it installed for $450 plus $150 for oil. In that case any recommendations on where I could get one?
Are you referring to the transmission oil pump or the engine oil pump?
I am not aware of any used ZF 6-speed automatic transmissions that cost $450. From where did you get that pricing?
Old Jul 31, 2015 | 08:20 AM
twh's Avatar
twh
Engine: N52
I assume that is a junkyard sourced transmission.
ali-d1936
Jul 26, 2015 05:32 AM
Rudy
Aug 15, 2009 06:40 PM
1esquire
Lounge
Aug 8, 2008 11:01 AM
Mr 5er
Lounge
10
Mar 20, 2006 06:06 PM
