Transmission Slam
Hi everyone, this is my first post.
I have a UK Spec. E60 late 2003. I'm not the first own of the car. I've read a number of links on this forum about Transmission Slam and I'm certain that I'm experiencing this issue. That is a harsh jerk when coming to a stop.
I've just come back from my local BMW dealer who said that an 'up lift' to the gear box will reset all the adaptive learning of the transmission to factor default and this slam will disappear. This should have taken 30mins. Over an hour later I asked how much longer as I had come out on my lunch break, another 20 mins later! Basically, the 'up lift' programming would not take and the test drives by the tech proved it so they did not charge me. But he did not offer me any alternative diagnostics to rectify the problem.
I did speak to him about upgrading the CCC to the latest version and he advised not to. He said if it failed could cost ME ?XXXXXX!! I was a bit shocked. Its a BMW, in a BMW garage, programmed by a BMW tech with a BMW PC why should I have to pay for BMW parts if the programming fails?
Its like going in for a service and the tech drives the car into a wall and they say I have to pay for the repair!
Is it possible that the CCC programming can fail and do I have to pay for the replacement modules?
thanks,
Sorry for the long post.
thanks,
My Ride: '04 530d Executive, all options except sunroof and comfort seats
ECU remapped by ZipTuning to 260+bhp.
First the CCC:
Yeah, a lot of dealers said the same thing to me. I eventually found a dealer that would update it assuring me nothing could go wrong. (It didn't, by the way)
Flashing the CCC is a timely and kinda dangerous thing to do. You need a steady power supply (battery hooked up to a charger) and a stable laptop.
A hang or instable voltage could cause your computer to break.
Then the transmission slam:
All my computers were updated to the latest version while programming the CCC, also the ECU (which destroyed my tuning software) and the transmission computer.
This did reduce the slamming somewhat, but it's not gone. I also have the problem when flooring it (kick-down) and suddenly lifting off the pedal. The tranny will shift up immediately and it will kick a bit.
As far as i know, there's nothing that can really be done about it apart from swapping with a newer transmission.
My Ride: 2006 525XI, Jet black on Dakota beige. Premium and winter packages. I consider myself a purist and intend to keep my car absolutely stock and shiny.
2008 328I Convertible, Sapphire black on beige interior. Premium package, NAV, iPod adapter.
Retired: 2002 325I, Titanium silver on black leather. Premium package. Absolutely stock and proud of it.
Originally Posted by OverSoft' post='768840' date='Jan 15 2009, 05:00 PM
First the CCC:
Originally Posted by porsche911targa' post='768966' date='Jan 15 2009, 07:17 PM
I agree. A tranny replacement took care of this for mine.
Originally Posted by porche944' post='769400' date='Jan 16 2009, 11:00 AM
I don't know how I can get the tranny replaced as the car is 5 years old. So I was relying on a CCC upgrade. I was told that I would have to pay for any modules that 'failed' during the upgrade is that right?
I have no tran slam in mine. It was updates to the latest software in October. They seem to have got round tran slam by leaving the car in 2nd gear when you come to a stop.
If I come to a complete stop for say 20 seconds when I pull away it will be in 1st gear.
If I come to a stop for say 5 seconds it will still be in 2nd, so when I pull away it does nothing while it changed into 1st gear then we are away.
That is what my cars does and reading on here serveral others do the same. Is it to over come trans slam? Not sure but I have to slam.
I have heard if the flash fails BMW will charge you for the extra labour and came be very expensive. I feel the same as you. All BMW's gear including the tech and when they mess it up they charge you
Research on the board said a software upgrade was required. My dealer said that per BMW software would not fix the problem but they agreed to update it anyway. This fixed most but not all of the problem. My car is under warranty.
If a BMW dealer told me that they might screw up my car doing a BMW software update and that I would have to pay for their mistakes I would laugh at them. No way in hell would they get away with that where I live.
My Ride: 2015 535D M Sport
I'm not so sure that the trans slam is actually fixable. I've had two software updates specifically to fix it and although I seem to get it less often than before, it still occurs. I had one just a couple days ago after going more than a year without one. The ZF 6 speed auto is well known for this problem (just Google on it) since it first showed up in Jaguars about 5 years ago and they apparently still haven't been able to completely resolve it. If a software fix attempt is going to cost you anything, you might not want to bother.
Thanks guys for all your information.
I live in the UK.
I think a simple fix to save the tranny, would be to wait until the car stops and then shift the gear to 1st.
I'm going to try another BMW dealer and see what response I get.
Thanks once again to everyone.
I live in the UK.
My Ride: 2005 545i
