Transmission Oil Change Question
Old 06-05-2015, 08:16 PM
550sport87's Avatar
My Ride: 08 550i sport. n62tu
I've seen 180 and 200,000+ miles come in with original Trans fluid and gear oil. Not to say this is a wise thing, but if you're not towing or beating the hell out of your car, Trans fluid doesn't break down like oil, it doesn't get as hot, it's not contaminated with fuel and moisture like oil etc etc.
Old 06-06-2015, 11:41 AM
Tetonfiber's Avatar
My Ride: 535i XDrive Touring
Model Year: 2009
Engine: N54
Change that fluid! Fluid changes have resolved all of my rough shifting issues. 155K miles and the transmission shift as if it were new.
Regarding the AGS-Adaptive Transmission Control, the AGS readjust itself every time the car accelerates from a stop. Change the fluid and the AGS will learn its new parameters.
In short the dealership is counting on selling you a new transmission in about 40K miles.
Old 06-06-2015, 01:04 PM
KyleB's Avatar
My Ride: 530i
Engine: M54
Originally Posted by 550sport87
I've seen 180 and 200,000+ miles come in with original Trans fluid and gear oil. Not to say this is a wise thing...
It's most definitely not a wise thing. Transmission fluid gets contaminated, and this contamination is exactly what leads to solenoid failure. For whatever reason, the 6HP generation of ZF gearboxes appear to be especially prone to failures at shift solenoids. I also saw them come in to my shop with similar mileages and no service history. Some of them came in on tow trucks...
Again, straight from the horse's mouth:
http://www.zf.com/media/media/docume...hselkit_EN.pdf
gamble if you wish, but it could end up being an expensive bet.
Old 07-16-2015, 12:37 PM
srschang's Avatar
I just got done changing the transmission fluid on my wife's 2008 528Xi a few weeks ago. It looked pretty good overall, this was the first time it was changed, 148,000 miles. I also reset the adaptations. It really felt better, crisper shifts. But now it's learned the way my wife drives and it's back to the same old sluggish shifting, just like it was before I did all the work. Well, at least I know the fluid is fairly clean and the pan/filter are new.
Old 07-20-2015, 05:47 PM
E60GUMSL's Avatar
My Ride: 2004 530i Alpine White/Grey/6AT
I would change the Oil.
I changed mine at 80k miles & wished it was done earlier. The oil was dirty & dark. If I had owned it earlier I would have done it for sure.
Old 07-23-2015, 03:26 PM
banglenot's Avatar
My Ride: 530i base, blue with saddle leather
Engine: N52
There is some rationality to the old school guys 150K+ concern about new fluid. That the old stuff gets incredibly crappy and the new detergents loosen up the crud deposits, so that it finds it's way into the valvebody ports, etc. So if the tranny is way up there and the fluid is original, I'd have to think about whether there's a risk.
But: I go with ZF's recommendation and change it every 60K or so. That way the fluid never gets crappy, and 150K+ is like any other mile.
Old 07-28-2015, 04:22 AM
fast's Avatar
My Ride: White/Tan, Nav, comfort seats, sport steering wheels, sport suspension, active steering, rear window shades, rear shade, heated seats
Model Year: '07-530i
What fluid/transmission pan kit are you guys using or could recommend for an '07 530i? Can not find the BMW OEM fluid so I need help.
Would also need a feedback on this adaptation thingy and does it apply to our car?
Thanks for being patient with me
Old 07-28-2015, 05:24 AM
twh
twh's Avatar
My Ride: 2006 BMW 530xi 6MT
Engine: N52
A good source of transmission maintenance parts is The CTSC - ZF Parts.
You'll see them in many threads including KyleB's DIY transmission thread.
Just ordered a kit for wife's 2009 X5. Came a couple days ago. All ZF parts and fluid. Well packed. Good price.
Old 07-28-2015, 05:36 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
The OEM fluid is ZF Lifeguard6, I always get my transmission service parts and fluid from thectsc.com.
Old 07-28-2015, 05:47 AM
fast's Avatar
Saw this right after sending you a PM.
What type of transmission (model) is there in an '07 530i?
Thanks
Quick Reply: Transmission Oil Change Question
