DIY people - has anyone used any other Transmission oil without any issues in there E60 Auto apart from BMW oil (which basically is Shell M-1375.4). If yes, can you please contribute the brand and type of oil.
So far I have the following; ZF Lifeguard 6 Pentosin ATF1 |
Hi
I just reasently had this issue up , please see : https://5series.net/forums/topic/125...tc-gear-boxes/ I have ended up with using the Mobil LT71141 ( 1/3 the price of Shell M-1375.4/ZF-Lifeguard 6 ) , and so far with out any problems :) Kind Regards BenAnd |
Originally Posted by BenAnd
(Post 1469382)
Hi
Hi
Have just purchased 20 Litre of Mobil LT71141 ( with prod. date 05-2012 ) so I can't imagne that it is "obsolete" , look at E-bay and you will see it can still be purchased with out any problems from several suppliers/sellers. Kind Regards BenAnd |
1 Attachment(s)
Okay list so far with a comparison, any other choice?
BMW Original - Shell M-1375.4 ZF Lifeguard 6 Pentosin ATF1 (Manufacturer - CRP Industries) Mobil ATF LT 71141 MotorCraft Mercon SP ATF AMSOIL Synthetic Fuel Efficient |
Redline also there should be data sheets I posted in one of the DIY threads
1 Attachment(s)
Originally Posted by 525iEnjoy
(Post 1469427)
BMW Original - Shell M-1375.4 ZF Lifeguard 6 Pentosin ATF1 (Manufacturer - CRP Industries) Mobil ATF LT 71141 MotorCraft Mercon SP ATF AMSOIL Synthetic Fuel Efficient Redline - Synthetic ATF Castrol Import Multi-Vehicle So far Redline looks the best. Feel free to add your experience. |
shops use redline for higher torque applications like 535, 550 etc... for little 2.5 or 3.0 I would run the others
If you talk to ZF there is no substitute. For a couple hundred bucks why take a chance.
Originally Posted by mfrasca
(Post 1470247)
| All times are GMT -8. The time now is 02:17 AM. |
