Transmission Oil
Old Sep 17, 2012 | 07:29 PM
kskane's Avatar
My Ride: E60 M54
Model Year: 525i 2004
DIY people - has anyone used any other Transmission oil without any issues in there E60 Auto apart from BMW oil (which basically is Shell M-1375.4). If yes, can you please contribute the brand and type of oil.
So far I have the following;
ZF Lifeguard 6
Pentosin ATF1
Old Sep 17, 2012 | 09:58 PM
BenAnd's Avatar
My Ride: BMW e60 525IA 12/2003
Hi
I just reasently had this issue up , please see :
https://5series.net/forums/topic/125...tc-gear-boxes/
I have ended up with using the Mobil LT71141 ( 1/3 the price of Shell M-1375.4/ZF-Lifeguard 6 ) , and so far with out any problems
Kind Regards
BenAnd
Old Sep 17, 2012 | 10:26 PM
kskane's Avatar
My Ride: E60 M54
Originally Posted by BenAnd
Hi
Kind Regards
BenAnd
Is Mobil LT71141 old and obsolete and new one is called Mobil 1 Synthetic ATF? (see http://www.eclubes.com.au/products/v...l-atf-lt-71141)
Old Sep 18, 2012 | 02:41 AM
BenAnd's Avatar
Hi
Have just purchased 20 Litre of Mobil LT71141 ( with prod. date 05-2012 ) so I can't imagne that it is "obsolete" , look at E-bay and you will see it can still be purchased with out any problems from several suppliers/sellers.
Kind Regards
BenAnd
Old Sep 18, 2012 | 04:10 AM
kskane's Avatar
My Ride: E60 M54
Okay list so far with a comparison, any other choice?
BMW Original - Shell M-1375.4
ZF Lifeguard 6
Pentosin ATF1 (Manufacturer - CRP Industries)
Mobil ATF LT 71141
MotorCraft Mercon SP ATF
AMSOIL Synthetic Fuel Efficient
File Type: pdf
Old Sep 18, 2012 | 06:07 AM
525iEnjoy's Avatar
Redline also there should be data sheets I posted in one of the DIY threads
Old Sep 20, 2012 | 07:30 PM
kskane's Avatar
My Ride: E60 M54
There you go, Updated comparison list
ZF Lifeguard 6
Mobil ATF LT 71141
Redline - Synthetic ATF
Castrol Import Multi-Vehicle
So far Redline looks the best. Feel free to add your experience.
Old Sep 21, 2012 | 06:30 PM
525iEnjoy's Avatar
shops use redline for higher torque applications like 535, 550 etc... for little 2.5 or 3.0 I would run the others
Old Sep 22, 2012 | 06:22 PM
mfrasca's Avatar
If you talk to ZF there is no substitute. For a couple hundred bucks why take a chance.
Old Oct 2, 2012 | 04:23 AM
kskane's Avatar
My Ride: E60 M54
Considering you spoke to ZF, did you ask them if they make the oil or they re-brand it?
