Transmission Malfunction
Old 01-25-2014 | 07:58 AM
darnell moore's Avatar
My Ride: 550i
Unhappy Transmission Malfunction
I have a 2005 545i. I have changed the filter and oil with ZF lifetime 6. Transmission feels and shifts ok sometime. When the problem does occur its between 3d and 4th gear. Feels like theres studder and then a hard shift to 4th and then the transmission malfunction warning comes. After shutting the car off it goes away, sometimes coming back and sometimes not. I got the error code P17E8, manufacturer control transmission. Can someone give some advice as to what to do. Thanks you so much in advance.
Old 01-25-2014 | 09:08 AM
BimmerFan52's Avatar
Attachment 143863
Previous similar problem.
05 545i Transmission Surging Issues help! - Page 28 - Bimmerfest - BMW Forums
You can try an adaptive reset first.
Old 01-25-2014 | 08:20 PM
sbchris's Avatar
My Ride: 550i
I had something similar in my car and would get the trans malfunction also with no moving gears after the error.
Being under CPO, BMW replaced about 20K worth of stuff. New trans and everything electrically related to the transmission also, shifting, ecu, etc.
Sounds like your trans is toast!
Old 01-27-2014 | 06:47 AM
Shlooky's Avatar
My Ride: 545i
Whats the mileage on your 545i when you noticed the problem? I have 203000 Kms (126138.3 Miles) and though the tranny is still behaving, I fear the same will happen to me eventually.
Thanks
Old 01-27-2014 | 09:14 AM
My Ride: 550i
Thanks
Just over 193000 miles. I'll keep you posted.
Old 01-27-2014 | 11:49 AM
Shlooky's Avatar
My Ride: 545i
Spoke to a couple of friends, they recommend you have the tranny rebuilt. Costs you less than a new one and they can put better parts in it. Just find a reliable place that fixes imports especially BMW and you're good.
Old 01-27-2014 | 12:47 PM
My Ride: 550i
Thank you so much. Can one guide me to a reputable place here in Massachusetts And what should I expect to pay.
Old 02-01-2014 | 06:00 PM
mfrasca's Avatar
The valve body is most likely the problem. I would recommend a rebuilt unit from ZF. The swap will still cost you around $3,000 with labor.
Old 02-17-2014 | 08:54 AM
mouthyman's Avatar
My Ride: 525I
had exactly the same problem, and after having the fluid changed first also it developed this issue.
I had the entire transmission remanufactured although I am still experiencing the same issue
I have been told the gearbox is now fixed but due to a faulty Light control module the adaptive learning process is being interrupted and the symptoms are still appearing.
anyone think this is right?
Old 02-17-2014 | 09:03 AM
twh's Avatar
twh
My Ride: 2006 BMW 530xi 6MT
Engine: N52
I can't say it is out of the realm of possibility, but I don't believe it. If they think the light control module is fault, why don't you disconnect them both and drive the car. What happens.
I would also says that if the problem developed after changing the fluid, perhaps the wrong fluid was used. Automatic transmissions are very picky about the fluid type.
Quick Reply: Transmission Malfunction
