Transmission Help
Old Aug 22, 2013 | 08:44 PM
TU2TLE's Avatar
My Ride: Silver 550i: Orion V2 - LCI Tail Lights - VRM 710 (Powder Coated Matt Black) - Magnaflow Cat Back Exhaust - Painted Brake Calipers (Red) - Painted Rear MTEC Kit (Black) - Window Tint (Windshield 70% - All other Windows 55% - Smoked Side Markers
Default Transmission Help
Hey guys. I had a leaking transmission pan on my 550 and had it replaced. A day after I got it replaced I noticed the that the Transmission jerks right before i come to a complete stop. This only is happening in Drive. not when I am manually changing the gears. and it only does it going from 2nd gear to 1st. Now it doesn't do it all the time and I am uncertain of what the problem is. I thought there was not enough oil in the transmission so i took it back to my mechanic and I had him top it off again. Issue is still there, and of course there is no check engine light. Any tips?
Old Aug 22, 2013 | 09:33 PM
H F's Avatar
H F
My Ride: 2005 545
I think you need an update for the trany
Old Aug 22, 2013 | 09:38 PM
TU2TLE's Avatar
can you elaborate...
Old Aug 22, 2013 | 09:58 PM
H F's Avatar
H F
My Ride: 2005 545
Its a second to first gear serge (jerk).. i had that problem 5 years ago. The dealer did a software update on the transmission. It solved the jerking issue and has never done it again
Old Aug 22, 2013 | 10:03 PM
TU2TLE's Avatar
thank you. I will look into this. I will also let you know how it turns out.
Old Aug 22, 2013 | 10:28 PM
H F's Avatar
H F
My Ride: 2005 545
[.[/QUOTE] Read this entire thread lots of good info Start reading from the first page
07 530i jerk forward when coming to a stop Please HELP - Page 3 - Bimmerfest - BMW Forums
Old Aug 22, 2013 | 10:34 PM
H F's Avatar
H F
My Ride: 2005 545
Read this thread also. Lots of good information about the surging issues.
05 545i Transmission Surging Issues help! - Bimmerfest - BMW Forums
Old Aug 23, 2013 | 01:52 PM
Shlooky's Avatar
My Ride: 545i
Ok so the surging thing (happens to me too) is only in 5th gear. it occurs in automatic mode while driving between 40 and 50 Kmh or around 40Mph.
The car wants to shift to 6th gear but it's like it gets stuck or something. When the surging occurs, put the car in 5th gear manual shift mode and you can replicate it at any speed. This is definitely a flaw in the e60 automatic tranny's. The good thing is I can actually reset it while driving, by placing the car in 5M and keeping it there while driving on the highway. The tranny will surge but eventually stop for a good two weeks. then it'll come back.
the best thing to do is to buy a manual shift BMW if you can find one. way less headaches, and more fun
Old Aug 23, 2013 | 11:32 PM
TU2TLE's Avatar
Thanks for your help HF. hopefully this gets resolved within a couple days
Old Aug 23, 2013 | 11:55 PM
Boost7's Avatar
My Ride: E60
Model Year: 2005
Did the mechanic reset the adaptation? The ignition on and stepping on the gas pedal for 30 doesn't do anything. I would try finding a shop that can help you reset the tranny adaptation first.
