Transmission flush
I have a 2004 530i with about 54,000 miles. The dealer says it needs a transmission flush, and they want $750 to do it. They say it needs some type of "special fluid." They also wanted $220 to change the accessory belt, but I'll do that myself for the $25.
Is a tranny flush something a local shop could do (e.g., a transmission shop that can use synthetic fluid), or is there something special with BMW?
But, if you bring it to an indy shop and they screw it up....you'll be paying for a new tranny...
However when I asked an independent shop they said they would do it but it would cost $800. The filter is part of the pan and that's $250. The fluid is $30/quart and you must use the BMW fluid.
My Ride: 2004 545i TITANIUM GREY II on Black Dakota Lthr, Comfort Seats, Sports PKG, Premium PKG, Active/Dynamic Drive, NAV, Winter Package.
BMW Transmissions were sealed since early 90s if not if earlier, we have a 1995 525i and wanted to flush the transmission but we couldn't because it is sealed and no need as BMW suggests. This dealer that wants to charge $700 - $800 is a STEALER!!!!!! Don't do it.
Originally Posted by mhs525' post='1068460' date='Dec 5 2009, 09:05 PM
That is strange. I asked my dealer to change my transmission fluid and they said its a "sealed unit" with "lifetime fluid" and doesn't need to be changed.
Pay no more than $400.
Here is a good read for you. There are other compatible fluids besides Shell. BMW has an exclusive with Shell and it can't be found anywhere besides the dealer. Plenty have changed it with other compatible fluids, successfully.
https://5series.net/forums/index.php?showtopic=88129
Raj
Raj
