Transmission fluid comparison
Old 07-29-2014, 12:39 PM
  #61
texasmr2's Avatar
My Ride: Stock 2004 BMW 525i
Is the Mercon SP a strictly Ford dealer p/u or do some of the better known auto part's stores sell it?
Old 07-29-2014, 05:31 PM
  #62
BimmerFan52's Avatar
Search the Web.
Old 07-29-2014, 05:55 PM
  #63
turboawd's Avatar
My Ride: 2006 BMW 550i
Originally Posted by BimmerFan52
Search the Web.
or certain stores stock it or can order. i think oreilys might stock it.
Old 07-29-2014, 06:56 PM
  #64
gcalo's Avatar
My Ride: 530i
Engine: N52
If you find an O'Reilly Auto parts store and ask for a case price it should be about $5.50/pint.
If you purchase individually I have seen it from $7.50 $8.50!
I am sure most auto parts places would extend a very good case price.
Old 07-29-2014, 07:51 PM
  #65
texasmr2's Avatar
Search the Web.
If I wanted to do that wouldn't it negate any need for this forum?
Originally Posted by gcalo
If you find an O'Reilly Auto parts store and ask for a case price it should be about $5.50/pint. If you purchase individually I have seen it from $7.50 $8.50! I am sure most auto parts places would extend a very good case price.
Thanks and if I could climb onto my roof I could spit on the local O'Reilly's I have been using for 20+yr's.
Don't mean to sound like a smart ass towards BimmerFan52 but this is the first I have ever heard about Mercon SP, the only stupid question is the one not asked, right?
Old 07-30-2014, 11:02 AM
  #66
texasmr2's Avatar
Smile
I just spoke with the O'Reilly in front of my neighborhood and they have seven quarts in-stock of the Mercon SP on a back room shelf so apparently they do not sell a lot of it. Yes I failed to check my owners manual, I know, but will I be safe if I purchased all seven or do I even need that many quarts? Oh and O'Reilly is asking $7.49/quart and no discount for a case that I believe was mentioned as being 4Q/per case.
My apologies for getting semi off topic and into the maintenance but I figured why start a new thread, thanks everyone for your help.
Gregg
EDIT: Just spoke with Mike at BAV Auto, ext:1267, and he informed me I will need 6 liters so I should be fine with purchasing those 7 quarts.
Old 07-30-2014, 12:40 PM
  #67
KyleB's Avatar
My Ride: 530i
Engine: M54
Correct; for a simple drain and fill or pan replacement you'll need appx 6L. If you are removing the Mechatronic for any reason, you'll have a bit more fluid escape requiring one more liter of ATF to be on hand.
good luck!
Old 07-30-2014, 12:55 PM
  #68
texasmr2's Avatar
Wink
good luck!
I saw the Mechatronic sleeve being recommended on the BAV Auto website when replacing the filter assembly. Seeing as I am once again a full time student my funding is limited and with only 89K easy miles on the car I think a simple drain and fill will suit my needs for the time being.
Thanks Kyle,
Gregg
Old 07-30-2014, 02:56 PM
  #69
gcalo's Avatar
My Ride: 530i
Engine: N52
$7.49 seems to be an average quart price.
I am surprised that your O'Reilly did not offer a case price.
I complained that $7.99/quart was too high and the clerk offered a case price at $5.50/quart!
I could not turn that down.
Seems to be 5.5 to 6 quarts for a complete re-fill.
Old 07-30-2014, 05:37 PM
  #70
KyleB's Avatar
My Ride: 530i
Engine: M54
Thanks Kyle,
Gregg
When you're under the car take a look at the sleeve. If it isn't leaking leave it alone. Sleeve replacement requires pan removal.
Quick Reply: Transmission fluid comparison
