Transmission fault ZF gearbox error code 4F95
My Ride: BMW 520D 2009 BE
Hi guys,
Had a transmission fault about 2 months ago with the error code in the title, told to start with Oil/filter change in the gearbox.
Just been to a BMW specialist in Swindon to have the gearbox fluid/filters/gaskets replaced but its still having the same problems,
Not major but at around 60/70mph 4th or 5th gear revs about 1000 rpm more before clunking into gear. doesn't appear to do it on other gears really, and it doesn't do it all the time which is strange. also when cruising at about 40mph rev counter is flopping up and down like its not happy.
Any ideas on what to do next, or what to try as I am stumped?
Any help appreciated.
Cheers
Cheers
