Trans FLuid
Old Apr 13, 2011 | 05:26 AM
vrmoreno3's Avatar
My Ride: 2006 530i, Cold Weather, L7 sound, Bluetooth, Satellite, BMW Roof Rack
It is almost time for my trans fluid replacement (100,000 miles). Anyone that has had this done, have you noticed any difference?
Old Apr 13, 2011 | 06:32 AM
pcy's Avatar
pcy
I recommend trans fluid change. That will give you a chance to look at the trans fluid and see of there are any particles in the fluid and also the condition of electrical connector for any leaks. If you are planning to keep the car for few more years, it's a good idea. Change the filter (pan is part of the filter) as well. I have seen the 'kit' (pan/filter, gasket, drain plug seal ring) for around $175. Trans fluid is around $25 per Ltr.
As for noticing any 'difference', I am not sure what difference one can expect... Nothing should change except the shifts may be slightly better. The fluid/filter change is NOT for feeling any difference, it's more of a maintenance to prolong the life of trans.
Old Apr 13, 2011 | 06:39 AM
525iEnjoy's Avatar
There is a huge writeup in the DIY section under ZF.... Like others have said dont pay 25/liter when you can pay 5 to 15! Yes thats 5.00 to 15.00 per liter no joke!
Old Apr 13, 2011 | 07:48 AM
pcy's Avatar
pcy
Petosin doesn't seem to be a bad alternative. Pentosin is around $18 per Ltr.
If you are replacing entire trans fluid (including trans cooler and torque converter), then any trans fluid that is approved by BMW should be ok. However, if you are only dropping the filter/pan and you are only replacing approx 5 ltrs (out of 9), then I am not sure if there are any issues with mixing old original BMW fluid and any other new off the shelf trans fluid. If it is my car, I wouldn't mix.
Old Apr 13, 2011 | 04:40 PM
belarus27's Avatar
ive done it... (Motorcraft fluid from for Dealer)
took me around 5hrs.
very irritating process if u do it at home
Old Apr 14, 2011 | 12:32 AM
pinguhk's Avatar
My Ride: Mini Cooper
wow 100,000 miles
I changed my at 27961 miles maybe because the roads in HK are very hilly and need to push the cars more, unlike the smooth flat road you guys have.
yes it will be smoother changing from 2nd to 3rd going uphill this is for a auto
here is my link
http://forums.5serie...ost__p__1035406
Old Apr 14, 2011 | 09:39 PM
gwf545's Avatar
My Ride: 2015 535D M Sport
Kit is here: http://www.thectsc.com/index.php?p=c...parent=61&pg=1 I ordered one plus the sealing sleeve which is prone to leaking, but have not had time to install it yet. The site also has directions to do the job here: http://www.thectsc.com/index.php?p=p...e_id=tech_info
Old Apr 16, 2011 | 11:04 AM
400killer's Avatar
Most dealers only change the pan filter and the fluid in it. Which is acceptable since they are using the same fluid. I would stick with the same fluid as the clutch packs and bands in the tranny absorb it, and I have had trouble with manual transmissions in the past "mixing" fluids motorcycle trannys, the clutch gets grabby, etc. I prefer to have the tranny flushed and the filter changed. I have had it done on my 2000 4runner every 40,000 and its now at 225,000 miles, with now signs of slipping even with intermittent towing.
Old Apr 17, 2011 | 05:02 AM
pinguhk's Avatar
NEVER USE ANY OTHER BRANDS OF FUILD APART FROM WHAT BME USE.
EVEN THE SAME BRAND HAS DIFFRENT MODELS
Old Apr 17, 2011 | 05:13 AM
pinguhk's Avatar
I thort BMW dealers never change the oil in transmissions.
