Tranny Slam
Old 05-06-2010, 06:39 AM
anand_rahim's Avatar
All,
I recently had my transmission pan, oil and filter changed after I noticed some oil spots on my driveway and very hard shifts. I didn't have time to do it myself so I had to shell out $740 to a local mechanic to complete the work. So far I haven't experienced any tranny slams or slips while driving. Usually when I did a rolling stop and then stepped on the gas again, my tranny would always slip but that has not happened yet.
If you have experienced tranny slips, I would recommend performing this DIY:
https://5series.net/forums/topic/881...-drain-refill/
The parts are cheap, but it could save you a lot of money in the long run. Good luck!
Anand
Old 05-06-2010, 08:25 AM
flyingpuck's Avatar
My issues with transmission slam were only overcome by transmission replacement, no other attempted repair made ANY difference! If this works for others, that's great!!
Old 05-06-2010, 09:17 AM
joebaggg's Avatar
My Ride: 2013 535i xDrive AW/Black M-kit
wow i was soooo expecting the worst when i saw the title of this thread... is that weird that i still clicked on it to check it out??
Old 05-06-2010, 11:14 AM
EBMCS03's Avatar
Never judge a thread by its title...
AKAlius's Avatar
Thanks for sharing Anand.
Old 05-07-2010, 07:44 AM
zanetti's Avatar
My Ride: e60 520d 2006 model
Just before changing the oil pan and atf of my 520d 2006 model with 130000km done i faced some jerk on the tranny when coming to a full stop. It's been 2 months after and except the jerks i face lots of slam on the changes. i'm quite disappointed because i think it's very early for tranny problems. on monday i will be at the dealer. Should i hope on a lost software of the tranny brain?
Old 05-07-2010, 09:23 AM
I had this ongoing battle with my dealer about the slam/slip, and each time they just said it was a software issue and required programming. They probably reprogrammed my car 3 times, and it still didn't make any difference. Having this repair done has been the only thing to give my car some relief.
Old 05-07-2010, 11:51 AM
sessionmc's Avatar
My Ride: 2004 545i Sport
I also had my 545i tranny slam fixed by changing the oil pan and filter resulting from a leak. At first there was no change but then the mech also had to reset the tranny computer so it could "re-learn" shifting i guess.
Old 05-07-2010, 02:39 PM
tex_phil's Avatar
My Ride: 04 525i, 04 Dinan M3
I'm personally scared to try this.
Old 05-07-2010, 02:48 PM
stoic1's Avatar
My Ride: '04 545i, sport pkg, premium sound, sprint booster,
Just recently I had my fluid and filter replaced and that took care of my problems also. My problem stemmed from coasting into red lights. If the light changed to green before I stopped, I would sometimes get the slam. Hasn't happenend since then.
Quick Reply: Tranny Slam
