TPMS Malfunction when cold
My Ride: E60 550i
Model Year: 08
TPMS Malfunction
This message pops up when cold outside temp approx. 25F or lower, no water in the trunk to cause RDC module corrosion or such, underbody antenna is also clean.
Anyone experiencing the same only when cold? The audio gong is really annoying during this period, after driving a while then error dissapears.
You sure it isn't just a drop in tire pressure because it is cold out? Did you check all 4 tires? All down the same amount more or less?
