TPM Tire Pressure Monitor
My Ride: G30 M550i
Model Year: 2018
Originally Posted by my530i' post='365829' date='Dec 10 2006, 08:01 PM
Your car is 2006, so I don't think sensor is needed
My Ride: 530i 6 speed
Originally Posted by ivan545' post='366097' date='Dec 11 2006, 01:22 PM
i have a july 2004 with a ftm, so if i put a new set of rims without the ftm sensors would that be a problem besides the warning messegs? thanks.
Originally Posted by drjochen' post='365828' date='Dec 10 2006, 07:59 PM
Thats exactly why I still have my summer tires on. I am afraid to change to my winter tires (which was not an issue so far on the east coast with the heat wave we had...).
Just think of the TPM sensors as metal valve stems that cost $30-$35 more than normal ones. Putting on winter shoes isn't that hard and shouldn't be an issue just because your car now uses TPM sensors as long as your tire shop has a clue. TPM sensors will soon be the norm.
Originally Posted by ImolaRedM' post='366171' date='Dec 11 2006, 03:14 PM
How hard is it to change a valve stem?
I have non BMW wheels so the dealer doesn't want to touch them. A friend of mine used a local Tire Rack recommended installer and they scratched 2 of his wheels (of course it was not their fault...).
My Ride: 2006 525i Silver Gray/Gray Dakota Leather | Steptronic | Cold Weather | Xenon | Premium Package
Modifications:
M Aero Kit | Carbon Fiber Kidney Grill | K&N Air Filter | Charcoal Filter Removed | Radenergie R10 Silver 20" soon | kW coilover V3 | SprintBooster soon | M5 trunk finisher
Next planned mods:
?Hamann quad exhaust + Hamann quad rear diffuser + Hamann Front Lip?
I do have this TPM menu on my idrive. That means that I need to move the sensor from my old wheels to the new ones right?
Modifications:
Next planned mods:
Hmm, yeah.. Then mine doesn't have any sensor. Mine only warns that a tire is low, but not specifically which.
My Ride: G30 M550i
Model Year: 2018
Originally Posted by ImolaRedM' post='366179' date='Dec 11 2006, 03:50 PM
Check your wheels... if you have metal valve stems and a silver valve stem cap with a little o-ring inside then you have them. My guess is that you don't have the TPM sensors but have the TPM that depends on your ABS speed sensor. The older system will only tell you that a tire is low and won't tell what tire specifically needs air.
