TPM Malfunction error
#21
My Ride: 2008 535i
I just opened the trunk under the spare tire there is the tpm malfunction unit and check if there is watter in the trunk disconnect the white tpm malfunction clean it up if whet and it should be ok i did the same after reading in this forum and i found water in the trunk and cleaned up disconnected the unit and the light went oof. Sorry for my english and good luck to you.
