TPM Malfunction
Old Sep 25, 2010 | 07:06 AM
StasGS4's Avatar
Yesterday I installed a used set of 172s with BMW OEM TPM sensors and now the TPM Malfunction warning is on. I checked and rechecked the tire pressure and tried reseting the TPM system several times with no luck. Does anyone know a way to diagnose which sensor it may be? The warning was not present with my OEM 124s.
I searched, but could not find the answer. Any help would be greatly appreciated. Thanks!
Old Sep 25, 2010 | 08:47 AM
billeul's Avatar
I assumed you re-initialized per the instructions in your owners manual.
Old Sep 25, 2010 | 12:38 PM
StasGS4's Avatar
yes, i have reset the tpm, but the malfunction warning is still there. i think it is one of the sensors, but i don't know which one.
Old Sep 25, 2010 | 01:26 PM
Diamond's Avatar
Banned
you need a bmw/scan tool to tell u which it is unless you want to replace al 4. Typically when changing wheels or tires you should change the sensors for 21 bucks each or whatever. They are finicky and get broken/bent when changin wheels and tires. I always change all 4 every 2 years when i put on new tires
Old Sep 25, 2010 | 04:04 PM
StasGS4's Avatar
Thanks for the info. Thats what I suspected. Who sells these sensors for 21 bucks? At that price, I might replace all four.
BTW the wheels I got came with tires, so I could not install new sensors without taking it to the tire shop.
Old Jan 7, 2012 | 07:03 PM
clemsonbmw's Avatar
Hey,
Did you ever figure out how to fix the issue?
I got the same issue by replacing the whole wheel set. Took it to the dealer, the shop took the tire apart and told me that the sensor is for a different model. I have the 2008 model, but I put the F10 wheels on them.
Old Jan 7, 2012 | 08:34 PM
luigi524td's Avatar
Originally Posted by clemsonbmw
Hey,
Interesting catch - the wheel-mounted TPMS for the F10's are different than the units specified for the earlier production date e60's. They are not interchangeable. Planned obsolescence
Old Jan 8, 2012 | 08:10 AM
StasGS4's Avatar
Hey,
In my case it was a single sensor that was malfunctioning on my second set of wheels. I ended up swapping one wheel at a time with my original set of wheels to see which sensor was triggering the warning message. I did a TPM reset every time I installed another wheel on the car. After three attempts I found the culprit and ended up replacing just that sensor. The other three sensors are still ok.
fabolous531
Oct 18, 2015 12:22 PM
alexbaldy
Sep 28, 2015 12:28 PM
benski
F10 Discussion
Sep 16, 2015 07:10 PM
fifthofjac
Aug 30, 2015 07:08 PM
TMK
E60 M5 Discussion
Aug 18, 2015 01:32 PM
