Torn - Should I keep the car?
On my last trip to the dealer I had to drive in on limp mode. It turns out that the crankshaft speed sensor was broken. Well, when the service advisor brought the ticket back to me he also notified me of the following:
Mechatronics Seal - Transmission Harness Seal $640.87
Sway Bar Replacement (Active Stabilization) $2380.89
Power Steering Hose/Line: Pressure line off pump w/resonator $961.46
Apparently, they found leaks in all of these areas. I've never replaced the transmission fluid and I'm at 88k on a 2007 550i Sport. He said they didn't need immediate repair, but they may be upcoming. They also suggested an alignment ($299) and rotate the tires ($89!!). The car is just about paid for, but I'm afraid of some huge repair bills. I'm very handy, but I'm not sure which of these I can tackle.
Prior to this, the car was CPO and while under CPO I had the Valley Cooling Pipe replaced (pfeww!). I've also already replaced the battery and the idrive unit. I suspect that the suspension may need replacement at this mileage, but I'm not sure. Any help would be appreciated. I bought the car with 59k about 2.5 years ago.
My Ride: 2004 545i 6 speed, Silver Gray A08, Gray leather
Mods: Hard-Wired Passport 9500ix LIVE , K&N Air + RPi Scoop, Mtech V2.1 AE, ACS pedals+Ebrake, flip up front plate, OEM 172's, Custom M Kit, M3 shift knob, Eisemann Race Exhaust
2005 X5 3.0 (the nightmare)
1998 528i SOLD @ 173K
you got raped man. find an indy shop....
My Ride: 2006 BMW 550i
my front sway bar leaked a little. turned out one of the hoses connected to it came loose slighty due to the movement. if this were the case with yours also, the dealer would not just tighten a loose hose, as they make more money to just replace the whole sway bar. get it checked out elsewhere, or look at it yourself.
The fact that they are asking almost $400 for an alignment and tire rotation should tell you everything. You can get both of these done (including laser alignment) for less than $100.
I would have an indy do the mechatronic sleeve and do a tranny service while they are in there. I would have them take a look at the other items noted by the dealer and get their opinion and a price quote. A reputable indy will tell you that you probably don't need half of the stuff the dealer mentioned.
As for the tire rotation, I bought the tires at Discount Tire and they'll rotate them for free. However, I'm now leaning towards keeping the car and putting some 19s on it. Possibly coilovers.
Is this something the dealership told you? I'm on my third BMW and have always done the alignment at an indy shop with the right tools. I never had any issues.
Actually, Discount Tire is the one that told me that. This was after they replaced a rim that was bent by my wife! Ugh, that's another story! I'll check into the indy shop angle. I'm also going to get under the car and evaluate these leaks.
My Ride: 2005 545i (SMG)
Titanium Gray
Black Interior, Anthracite Trim
M-tech kit
Sport Package
Premium Sound
Satellite Radio
Active Cruise
Comfort Seats
Navigation
Folding rear seats
I was under the impression that this had to be done by BMW since the vehicle has active steering. Is this incorrect?
If you did not have AS, then you could have an indy do the alignment.
