Tires size advice involving coil-overs and 20's
My Ride: E60
Hey guys,
I recently lowered by e60 530i with H&R coil-overs. Currently running 20 inch rims for the summer with 255/30/20 in front 20 offset and 295/25/20 in the back with 25 offset. I need to get new tires and really want to add side wall size for rim protection with a 245/35/20 and 275/30/20. Saw a lot of members are running the 35/30 series on here. Will I need to roll by fenders a 100% to run this set up? I don't slam my car too low with the coil-overs just low enough to eliminate wheel gap. Should I only jump up series size in rear because It's only a .6 inch difference compared to .9 front to OEM? Please need someone with this same set up or issue in the past to give me advice. Thanks in advance.
Andrew
Andrew
My Ride: 2006 530i mystic blue
i dont think u will have to roll ur fenders because ur new tires sizes arent as wide, just a little meatyer. if anything u might get some plastic fender well rub. if so just go up on the coilovers a few mm;s. or keep rubbing untill u make a nice lil groove in the plastic and it wont rub anymore
![Hyper](https://5series.net/forums/images/smilies/imported/hyper.gif)
