Tire Wear
My Ride: 2004 530i
Hey guys i`ve got tire wear on the inner left forward tire and outter right tire!Basically the car is killing the right side of the front tires!
on the driving wheel there is a very little offset to the right to keep the car going straight and if i put the driving wheel straight the car pulls to the left.
So do you thing its a suspension problem or a wheel alignment will do the drill?
Thxs!
Thxs!
My Ride: 2005 545 6MT
mine was doing similar. Ended up being combination of control arms and alignment. year and mileage might help to narrow it down. Mine was 6 years old with about 80K miles when I replaced control arms.
Wouldn't it be best to take your car to someone there to look at it and tell you what the problem is? It seems a bit crazy to buy bushing when they could be perfectly ok.
Chances are if they have never been replaced they are well past worn. But take it to a good indy and have them check, or jack your car up and see if there is slack in the control arm. Mine were so worn out that I could move them with my hand.
socale39
09-05-2023 08:30 AM
CertifiedOfficial
05-21-2015 12:42 AM
TexaZ3
05-06-2015 09:54 AM
