Unfortunately I don't have any pictures to share at the moment, though I'm curious if anybody has run into a similar situation as mine. 'Was hopping in my car this morning and noticed the front left tire sidewall on my factory Potenza RFT was bulging out about half an inch from where it should be. The surface area of the bulge is an oval shaped region- probably 2"x1.5" across. The bulge runs from about a half inch from the tread to about a half inch from the location of the tire bead. Has anybody seen anything like this before? Could this be the effect of hitting a ~2" elevated road surface at 40mph (the street I'm thinking of is where they're replacing the road and you drive on ground/grooved up road which is roughly 2" lower than where the real road should be until you reach a point where the newly laid road is) while running my KWv2's at 75% stiffness? The ka-thunk sound of hitting that 2" transition was unsettling. :(
I can probably drive on the bulging RFT for another couple days until I figure out what I want to do. Here are my obvious options. Please help me decide what I should do, or if there are other options: - Replace the RFT with another. Not sure if I have to replace both front tires in the process to maintain tread wear consistency across both front tires. Decrease the stiffness of my KWv2's in the process. I imagine this will cost something around $750 for tires, mounting and balancing. - Replace all wheels/tires with 20's and only drive the car on weekends (while being a little more careful and also decreasing the stiffness of the KWv2's). I just bought a Volvo as a daily driver, so this seems like a reasonable alternative which will only cost a little more than replacing both front tires. If I do decide to get new wheels and tires, where should I get them? I like the black satin apperance and style of the Miro M6 Time Attacks. Thanks. :) |
certainly a pothole! Go with 19" and drive every day!
Do whatever it takes to be able to drive it DAILY!! :thumbsup:
Get 20's and drive everyday!
Just make sure to get some high quality wheels and some tires that aren't rubber bands. |
A bulge on the outside of the tires sidewall means the sidewall is damaged.
IN BROOKLYN WE CALL THAT A Ti-Ti also TITS alot of TIS can be also call TITIES :P :D :lol:
What you have there is most likely the result of a pothole - called pinch-shock. When the tire hits a pothole hard enough, it can actually pinch the sidewall on itself between the rim edge. When this happens severely enough, it actually rips the sidewall liner from the inside and allows air to escape into the sidewall, leaking into the outer layer of the tire. That's why you see a bulge. Anyway, you definitely don't want to drive on it that way for too long because the integrity of the tire is now compromised.
Get 20s if you want to spend a ton on tires AND wheels and you hit potholes. |
| All times are GMT -8. The time now is 04:31 AM. |
