Tire pressure question
My Ride: Alpine White 2010 535 M-Sport
I have 135 style wheels, 18 inch non staggered with Bridgestone run-flats. It started getting cooler recently and the TPMs gave me low pressure warnings for the fronts. I understand cooler temps can drop the PSI of a tire. Checked inside the door and it states 35psi up front and 42psi in back when cold. The fronts were at 28psi, I added air and all is good. Today it was the backs and they were at 28psi. Seems like a huge drop from 42psi. These tires are new (CPO 535 I purchased in July) so I figured they would have been set to OEM pressure at the dealer.
Is it normal in a RFT to have a large drop in pressure due to the cooler temp? Should I be running the tires at OEM recommendations or is there a better setup? My thought is the dealer had all 4 tires at 35psi, but I wanted to get input from the pros on the forum. Appreciate the input.
Engine: N54
don't count on anything that assumes someone else put the proper pressure in.. Set the pressures yourself with a quality gauge based on the label on the door and monitor the pressure daily/weekly to see if you have a change that indicates a slow leak.
My Ride: 2012 535i X-driveSpace Grey/Black Dakota, Fineline Anthracite Trim; Executive Package (Rear View, Lumbar, Nav, Voice, SIRIUS, HiFi Pro) Technology Package (Hi Beam Assist, Lane Departure, Blind Spot Detection, Surround View) BMW Apps (Apps, Smart Pho
Model Year: 2012
+1
Dealer tire installers or their outside contractors probably didn't put the correct amount in. As stated, monitor the tires yourself for leaks.
My Ride: 545i
Engine: N62
I was just inquiring about correct tire pressure yesterday. There seems to be a lot of ideas as to what the tire pressure should be. On my 04 545i w/sport package, the Manual calls for 32F 35R. Fully loaded with luggage and at speeds over 100mph it called for 38F 42R IIRC. I know the door jam sticker is what we all look at but there is a big discrepancy between the two. I always bump mine up a few PSI per tire, but decided I would try what BMW recommends for a few days just to see how it feels. I may have to bump them up soon. Expecially with non-rft tires, the ride is just too soft. What is everyone else running tire rpessure wise?
