Tire Pressure Monitor
My Ride: 2007 530Xi - Navigation, Premium package, Steptronic.
Our 530xi spent the night in the 40 degree fahrenheit garage last night, was then driven for a while, and left to sit for a couple of hours in the 10 degree cold. When the Missus next fired up the car and drove about a block, the TPM alerted to low pressure in one or more of the tires (I dunno...I haven't seen it yet). Dealer SA on 'phone said they'd had a lot of calls this morning with the same problem. Suggested resetting in I-Drive, then see if problem goes away. Missus says car drives fine, and the tires all look inflated to her.
Has this been a problem in the past? I did a search, but didn't find anything regarding this condition.
My Ride: Alpine White/Biege 545i, CWP, Nav, Active Steering, Auto Step ordered 2/1/05
Safe thing to do it check the pressure with a gauge. When was the last time you checked the pressure and what was the temp at that time? I just had to add air in both my cars to compensate for the cold weather. We have had a mild winter up until now.
Yup exactly what I did, couple weeks ago we hit single digit in the evening and iDrive started to beep on front-left being low and initially I thought the weather may cause it drop and about to just reset it from the console but on 2nd thought I pulled into a gas station and got my pressure gauge out and found low on all 4 corners w/ front-left being the lowest.
that just happened to me this week after not driving the car for a while.. well when i received the message i pulled over and looked.. all the tires were inflated, but not fully. so i pulled into a gas station and inflated the tires a little more, but not fully. then i reseted the FTM in the idrive. it resetted and was fine.
My Ride: 2005 530i - Alpine white with auburn interior; tip, xenon, pdc, sirius, prem, cold weather, red reflectors and xpel.
It use to happen all the time with my car. It seemed to be a seasonal thing going from Fall to Winter and Winter to Spring. My dealer thinks it was a matter of the sensors being too sensitive. They have since updated the software & so far no problems.
