Tire Pressure
My Ride: 2006 550i | Silver-Grey- A08 | Premium - Sport Package | Adaptive Headlights | Logic 7 w/ CD Changer | Bluetooth | Park Distance Control | Xenon Headlights | Comfort Access [s]Sprint Booster V1[/s] | K&N filter - Stock Box w/ Charcoal Filter Removed | Clear Side LED Markers | Matte Black Grilles | RPI Air Scoop | RPI 550i GT Exhaust | 12" Kicker w/ AMP | Headlight Euro Overlays | ACS Rep Roof\Trunk Spoilers |MTEC V2 Angel Eyes | 6000k HID Fog Lights | 19" VMR v710 Stag Wheels | Hankook Ventus V12 Evo K110 Tires | Debadged | LED Courtesy Door Lamps | Sprint Booster V2 | Painted Calipers | M pedals\shift knob | HID License Plate Bulbs | R1 Drilled\Slotted Rotors | Hawk HPS Brakes| ACS replica front lip |
The other week I noticed my Hankooks were all set to 32 lbs. My max pressure is 50 lbs so I took all my tires up to 42 lbs to allow for heat buildup, etc. I seldom have anyone in the car, but the road gets damn hot down here in South Florida. I don't want the pressure too high to avoid excessive wear in the middle. What would you say is a good pressure for me to keep my tires at? Something tells me 42 lbs may be to high, I do notice the car taking the small bumps a little harder.
ummm I would recommend 38. thats what i use and my tires say max is 51psi... drive around and adjust as needed.
Check the placard on your driver side door jamb. It will tell you the recommended tire pressure settings for your car. It's OK to fun a few higher (3-5psi) if you like a taut ride but never exceed the max PSI on the tire sidewall.
But I'm running aftermarket 19" wheels with a higher max. The sidewalls are lower.
My Ride: See my signature
My 550 is a LCI running 19 inch style 172 wheels. My 19 inch wheels come with the car. The recommended pressure notated on the driver's side door is indeed 36 psi for the fronts and 44 psi for the rears.
Okay, just checked the tires since they been riding hard for the past 3 days. The range of pressure was 43-44 (cold in the shade) I took them all down to 40 lbs. I'll see how that goes for a few days. I really didn't like them riding so hard, but the 32 initial lbs was way too low. (felt like a mercedes - lol)
What's the MAX for your front and rears? Listed on the tires. For me to have my tires at 44 psi (cold) and the max is 50, that just really seems high. I heard if you tire pressure is too high you can get higher wear in the center of your tires.
