Tire Pressure
Maybe I can help, but the questioner's definition of "better" would make it easier for us to help.
If you increase the pressure of the rear tires, it will induce over-steer (more tendency, not spin-out over-steer)in relation to how much pressure you are increasing. If you increase the pressure of the front tires, it will induce under-steer. Over-steer will make the car feel like it turns in quicker, under-steer the reverse.
More pressure harsher ride, less pressure softer ride.
More pressure better gas mileage, less pressure worse gas mileage.
If your racing, first chalk the tire from inner sidewall to outer sidewall right over the face of the tread. Do a lap and you will see how much you are/are not running up onto the sidewall. If you are running up on the sidewalls, add air pressure. If not enough subtract air pressure.
The air pressure affects the aspect ratio of the contact area of the tire, which affects lateral handling and straight line braking. More pressure (within reason) elongates the contact area to more of an oval with the longer parts front-to-rear, better for braking. Less pressure makes the contact patch more circular thus making it wider than the previous oval contact patch example and will enhance lateral turns.
If this does not answer your question, then I would recommend my fellow members previous answer of following the door jamb sticker.
Originally Posted by 1600' post='527328' date='Feb 4 2008, 08:09 PM
On all the BMWs I've owned, the recommended tires pressures are the same in the manual, on the door jamb or from the dealer. If you change tire sizes check with the manufacturer. I don't think think that's a smart ass, it's just demonstrates a dram of intelligence.
My Ride: 2004 545i
Production date: 02/04
Color: Black Sapphire Metallic
Trim: Anthracite
Options: Sport package with STEPTRONIC, Premium Sound, Rear Sunshade, Xenon
Thanks Pennetta for your detailed explanation. This is what this forum is all about, the people who has more knowledge contributing. Don't we all who drive cars knows that the basic recommended information is posted by the door for the past 30 years. Each person has their own preference and just by sharing thoughts, that we gather this information and at the end of the day each to make their own judgement whats best for their own cars and driving pleasure/needs. Thanks CWS530 for your thoughts too.
Originally Posted by 1600' post='527466' date='Feb 5 2008, 09:00 AM
Testy aren't we?
My Ride: 2008 535i, 6spd mtx, Monaco Blue w/Beige interior. Sport, Preimum, Logic 7/HD/I-Pod/USB, Nav sys, rear sunshade, HUD, PDC, Split seats,
Since you have different wheels/tires on your car now, I'd start with 32lbs and go up/down in 2lb increments until you find what's best for you. I've always ran mine in the 30 - 32 lbs range - with the exception of the BMW which is the 1st car I've owned that has different pressure requirements between the front and rear tires. I'd be cautious using the max air pressure on the sidewalls as I've seen pretty high max amonuts on various tires (up to 44 - 50lbs) and that would be way too much air (IMO). Another thought, is with the lower sidewall tires, I don't imagine you want to be running on the low pressure side....short enough sidewalls as it is....too low and I'd think you might be in danger of pinching the sidewall over potholes, etc.
My Ride: 2007 BMW 550i Sport Pkg, 6MT
I run 34 all round.
It's almost 50-50 weight balanced and there is no reason to have a higher pressure for rear tires unless you have rear passengers frequently. Higher rear pressure could cause understeer too.
My Ride: E46 330, E60 550 on order: Carbon Black/Natural Brown, 6MT.
Originally Posted by ugggh' post='527637' date='Feb 5 2008, 05:01 PM
Slightly off topic here: My wife's Cayenne calls for 39psi front/49 psi rear. I did a double-take because I couldn't believe how high Porsche was recommending. Granted the Cayenne's pretty heavy but still, 49psi? Anyways I took them down to 35/39 and it rides much better now.
I don't know what size you 19s are, but mine are 245/35 front 275/30 rear.
