I need some advise on Tire pressure for a BMW 528i under hot weather like Arizona. what should be the PSI, I called BMW service advisor and he recommended me 40PSI, I was shocked to hear that.
And can you please recommend my any Air compressor for home. |
Originally Posted by fatboysam
(Post 1464965)
And can you please recommend my any Air compressor for home. I keep a compact air compressor in my garage - bought it from Sears about 10 years ago for about $100. It's been very handy to use - moreso than those little 12v jobs though I do keep one of them in the trunk of my Roadster. |
(Post 1464965)
And can you please recommend my any Air compressor for home. BMW recommends 32 psi front and 38 psi rear for the '08 528i's stock 225/50R17 tires. This is based on 'cold' outside ambient temperature (i.e., earlier morning after being parked outside overnight, not driven, and not exposed to direct sunlight), a full load, and speeds of <100 mph. Depending on actual tires and loads, you may need to experiment a bit. For example, BMW's cold tire pressure specs for my '06 E61 are 30 F / 38 R. So far, I like 33 F / 38 R for light-to-medium loads at legal speed limits. I have a Black and Decker air pump (120 Vac; without gauge) I bought many years ago at Sears. http://imgc.classistatic.com/cps/poc...4089bn_27.jpeg HTH, Jim / crewzer |
Where can I buy one of these pumps for the best price? My local Sears din't have it.
Thanks
Originally Posted by crewzer
(Post 1465128)
As mentioned above, check the bottom of the driver side "B" pillar for BMW's recommended cold tire pressure for the tire size that was supplied with the car. Additional information is on page 221 in the OM.
BMW cars recommends 32 psi front and 38 psi rear for the '08 528i's stock 225/50R17 tires. This is based on 'cold' outside ambient temperature (i.e., earlier morning after being parked outside overnight, not driven, and not exposed to direct sunlight), a full load, and speeds of <100 mph. Depending on actual tires and loads, you may need to experiment a bit. For example, BMW's cold tires pressure specs for my '06 E61 are 30 F / 38 R. So far, I like 33 F / 38 R for light-to-medium loads at legal speed limits. I have a Black and Decker air pump (120 Vac; without gauge) I bought many years ago at Sears. http://imgc.classistatic.com/cps/poc...4089bn_27.jpeg HTH, Jim / crewzer |
