Tire pressure 1psi loss/week normal?
My Ride: E60 545i
I'm running 20" tires and I noticed a slow loss of pressure. I pump the front tires to 40psi and in a little more than a month, they will drop to 35. This has happened a coupe times already. Is this rate of psi loss normal?
Administrator
Is this happening with one tire, or all the tires? If all the tires, what width rim and tire are you running? Could be you have a bad fitment.
My Ride: E60 545i
20x8.5 and 20x10 20mm offset AVG wheels w/ 245/35/20 and 285/30/20 Sumitomo HTR Z III tires. Fitment should be spot on. This is happening to the two front tires. Setup is also fairly new (less than 6 months)
My Ride: 545 modded the F out
Either you have a hairline crack, bends in you front wheels or you have a bad bead seat on them. Being that you mentioned it only being less than 6 months I highly doubt your wheels a cracked unless you purposely look for potholes.
Administrator
Maybe remount the two front tires and see if the problem goes away?
