Tire pressre sensor
![Arrow](https://5series.net/forums/images/icons/icon2.gif)
My Ride: G30 M550i
Model Year: 2018
Did your old rims (on this 2006 525i) have metal valve stems? In the iDrive settings menu, does it show the letters "FTM" or "TPM?"
TPM (or metal valve stems) means you have the system that uses sensors.
FTM (or no metal valve stems) means you have the system that uses rotational (ABS) sensors.
I am pretty sure that you do not have TPM.
I think that it started in the 2007 models (built in 4/2006).
As Rudy stated, your I-Drive should give you the answers.
You are probably lucky not to have TPMs, as it adds a little more trouble to installing your new wheels.
My Ride: G30 M550i
Model Year: 2018
I also forgot to state the more obvious part -- if you end up having FTM, then you simply need to initialize the system once you're certain that all your tire pressures are correct. Once that's done, the warnings will cease...
Good glad you caught yourself before I had a chance to blast you! hahaha J/K...
Yes All you have to do is reinitialize the FTP monitor..
My Ride: G30 M550i
Model Year: 2018
Yes All you have to do is reinitialize the FTP monitor..![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
My Ride: 2007 530Xi - Navigation, Premium package, Steptronic.
Originally Posted by Rudy' post='463611' date='Aug 29 2007, 01:27 AM
Or the FTM monitor...no files need to be transferred... ![Tongue](https://5series.net/forums/images/smilies/imported/tongue.gif)
My Ride: G30 M550i
Model Year: 2018
Originally Posted by ExGMan' post='466169' date='Sep 5 2007, 04:00 PM
Well, since we're well into this...I'm considering buying a wheel/winter tire combination from TireRack for my 2007 530xi. I don't have run-flats, and do have TPM. When I buy from TR, there's an extra $196 in the package for the TPM system (two pieces each wheel). When I get the new wheels & tires, can I just change them out (OE wheels off, TR wheels on), and then reset the TPM system?
socale39
09-05-2023 08:30 AM
slickrick
06-12-2015 04:10 PM
