Tire Monitor Question
Old 12-25-2007, 03:47 PM
rudeja's Avatar
My Ride: 2004 545i 6spd Man, 19' Breyton Wheels, Ipod Install, Parrot Bluetooth, AC roof and Trunk Spoiler
Ok guys,
My car came originally with Run Flat, but the previous owner change both tires and rims, to what you see below. I was driving home today and my IDrive screen pop up and say that I had a Flat tire , I got out and check but all my tires are fine, only thing I notice was the the driver side tire may need a little air but nothing serious. Can someone tell me what kind of situation I have here. Is my Tire monitoring working ok ?, is this something I should disable ?
Old 12-25-2007, 04:20 PM
EBMCS03's Avatar
Its working exactly the way it was suppose to. If any wheel is down by approx 7lbs or more compared to the other tires it will warn you.
Old 12-25-2007, 04:27 PM
rudeja's Avatar
Ohhh, I would expect it to say Tire low, not flat, it did not even say which tire was flat. Ok I will add some air to the low tire to see if the message goes away. Thank you
Old 12-25-2007, 04:36 PM
DrLev99's Avatar
FTM's won't tell you which one is "low" or "flat," just that one or more has an issue. Don't forget to reset your settings in i-Drive.
Old 12-25-2007, 06:59 PM
kscarrol's Avatar
My Ride: E90 M3
Model Year: 2011
As I recall, this is an older E60 so likely had the FTM. Yes, even a tire as low as 5 lbs has set of my FTM in my old 545. And yes, the system only tells you that there is a flat. In the newer cars w/ TPMS, it will say tire low and tell you which tire...
Old 12-25-2007, 07:10 PM
DrLev99's Avatar
My car has TPMS and the dash gives the generic warning about the low tire pressure indicator. Checking the i-Drive itself should tell you which tire is actually low.
Old 12-25-2007, 07:19 PM
JSpira's Avatar
Originally Posted by DrLev99' post='510571' date='Dec 25 2007, 11:10 PM
My car has TPMS and does not tell me specifically which tire is low. It just shows the low tire pressure warning.
TPMS is supposed to display the tires as green if pressure is correct and display in yellow a tire that is low. Not sure if it goes to red if it?s critical but it does indicate WHICH tire. FTM does not and just indicates there is a problem on one of four tires.
Old 12-26-2007, 02:36 AM
rudeja's Avatar
I think I have the older E60 , Production date was 11/03. So I have the FTM
Old 12-26-2007, 04:27 AM
Tommi's Avatar
My Ride: 2008 E61 520dA Alpine White
Mine is same age 08/03. It's called RPA in my I-drive. Simple technology is based on tire revolution sensor which monitors each tire speed. If one has lost pressure or gone flat it has its affects on tire diameter and speed. Please correct me if wrong.
I have got alerts once, and there was a screw affecting very slow leakage. I'm not sure but I think the I-drive message also told which tire was it.
Old 12-26-2007, 05:18 AM
bauska's Avatar
My Ride: 2008 Carbon Black 550i, Sports, Premium & Cold Weather Packages, Steptronic, HUD, NAV.
You can also tell by the tire valves. If it is a rubber one - no special equipment, FTM thru iDrive. Check the pressure in all tires and you will see which is low. I just went through this....I had a screw in my run-flat, but all tires seemed ok; however, the pressure in one tire was zero. As mentioned above, afterwards make sure you reset the FTM in i-Drive.
Quick Reply: Tire Monitor Question
