TIRE FLAT sensor came on.
on my way to pick up my wheels and the flat tire symbol came on.check all tire preasure and got 40 psi allarround.anyways got te new wheels on but when I go to the dealer will they even look at it.got an appt for tuesday,should I throw the stocker back on?
also I didn't think the 05 have tps cus it has rubber valve stem on them.I thought tps are all metal stem with sensor inside?
nasty, what do you have? e60 05 what? 545? sport pkg?
sorry its a 05 530i with sport package.i just did a reset and see if that will do it.
doe anybody know if the stock wheels have tps sensor?do i need to do anything with my new wheels?
My Ride: 2006 530xiT, Sep. 2005 build, silver gray/gray/black anthracite, Steptronic, Premium, Premium Sound, NAV, PDC.
Originally Posted by nasty50' post='584846' date='May 20 2008, 09:52 PM
on my way to pick up my wheels and the flat tire symbol came on.check all tire preasure and got 40 psi allarround.also I didn't think the 05 have tps cus it has rubber valve stem on them.I thought tps are all metal stem with sensor inside?
Originally Posted by Mr.PC' post='586430' date='May 22 2008, 02:43 PM
As you noted later, you tried a reset. That should do it. This system (I think you have the old TPM, as do I, which reads differences in rotation speeds, rather than a sensor on each wheel). Whenever you add air the system needs to be reset. I've had this happen.
dynodave
04-20-2015 12:23 AM
