Ticking lifters.
So I took my car in to the dealer for the recall on the battery cable and mentioned to them about this ticking noise. They said it's the lifters.
I did a little research and I guess BMW knows of this problem due to a flaw in design. Wondering if anyone else here has had this issue and had good outcome?
Here's a link on more information if anyone is interested. Ticking Lifters
I just don't want to get my car back with other problems arising, like bad gas mileage or something due to this fix. I've read horror stories about how new problems arises after taking your car in for service.
If the ticking noise is still there after I get it back, I'll just do the "spirited driving" fix.
My Ride: 07 530i Mystic Blue
I'm going to take my car in tomorrow for the same issue. See E60 members with the lifters/header getting replaced:
https://5series.net/forums/topic/934...eing-replaced/
My Ride: 2006 525XI, Jet black on Dakota beige. Premium and winter packages. I consider myself a purist and intend to keep my car absolutely stock and shiny.
2008 328I Convertible, Sapphire black on beige interior. Premium package, NAV, iPod adapter.
Retired: 2002 325I, Titanium silver on black leather. Premium package. Absolutely stock and proud of it.
I mentioned this to my SA and asked her if since this is the second replacement in less than a year and 6K miles, shouldn't they replace the heads as the internet says? She replied that they USED to do that, but found that it did not work in most cases. They figured out that just replacing the lifters AND the rockers does the trick. Since they only replaced the lifters, last October, they are now replacing both the lifters and the rockers.
One week into the repair, the car is very quiet. Of course, I won't declare victory for about two years.
Good luck to the OP.
My Ride: 530i
Engine: M54
Hey, I'm the OP on that thread. I'm happy to report that the car is still very quiet. I guess I can say that replacing the exhaust valve lifters did the trick.
Funny you should mention this. Just last week they replaced the HVA lifters and rockers on my E93 to fix the ticking noise. Naturally, I did a lot of research and it seems that the head replacement came at the second attempt (after they replaced the lifters the first time). When my car was in the process of being CPO'ed, last October, they replaced the HVA lifters for ticking noise.
your SA is wrong. BMW did redesign the cylinder head. here is a link to BMWs own SI stating how to identify an older casting vs. newer casting: BMW SI
The 'they used to do that, but it didn't work' procedure is the "bleeding" procedure whereby BMW tried to bleed air pockets from the lifter bores. So I guess she's half right.
I'd make a trip down there with a printed copy of that SI in hand.
I hate to say it, but this is why I spent 8 months hunting down a clean M54 powered car.
Look: SIB_1109071.pdf
NICE ! I mentioned it in passing, but the SA called me hours later and told me that they were going to keep my car through the weekend to work on it. So I guess they consider it serious enough to keep it for days and, I guess, they are going to swap out the lifters for the updated ones? I hope so. I'v read in previous posts that this sometimes fixes it and sometimes doesn't fix it. Gonna be done under warranty, so good for me.
