| Austin545 |
Nov 1, 2007 06:28 AM |
Every manual transmission I've driven before I have not had to blip the throttle while upshifting. Of course I blip the throttle on every downshift so I don't have to slip the clutch at all. Now with the 545 when I'm upshifting into 5th and 6th I HAVE to blip the throttle otherwise the clutch will engage with this nasty thud. I don't know if I should chalk this up to the clutch delay valve, but it is annoying to have to do that so I don't get the thud and make the passengers think I can't drive a manual. Also in the mornings when I first started out I have to slip the clutch more than normal and give it a little extra gas so I get a smooth engagement in 1st, 2nd, and 3rd upshifts. Usually from a dead stop I don't over 1000rpm before the clutch has fully engaged, in the mornings the car likes some more rpm and some slippage for a smooth takeoff. Any of you experience the thud upshifting to 5th and 6th without the throttle blip?
