Those of you using a battery tender...
#31
The car monitors the battery drain and charge state, and if you charge the car with a direct hookup to the battery, it does not see the battery charging. It will only pick it up if charged through the engine compartment terminal. You can end up getting a fault if there is enough of a change in the battery charge.
Chris
Vman33
03-14-2022 04:43 AM
