Those of you using a battery tender...
#21
Update on my high battery drain: I drove my 535 four times in 2 weeks, did not use the battery tender in these 2 weeks. I never had the high battery drain fault.
Yesterday, I decided to hook up the battery tender so I popped the hood and connected the battery tender up the positive and negative points under the hood. The next day as soon as I started the car, I had the high battery drain fault.
Would it have something to do with the hood open overnight?
#22
My Ride: G30 M550i
Model Year: 2018
It sounds like you don't need the tender anyway...
#23
My Ride: 2008 535i, Premium, Nav, Ipod
When you leave the hood open, it prevents the car from going to sleep mode. I use a tape over the hood switch and it allows the car to go to sleep mode.
#24
#25
My car is more of a garage queen. I won't use it in the rain or snow. So I'd like to keep the battery tender on it because I know I'll eventually kill the battery.
#26
This is really interesting -- I didn't realize that the hood being open prevents the car from sleeping. This would certainly explain the high battery drain error coming on whenever I use the battery tender. I suppose another way of dealing with this problem is to close the hood lightly over the wires.
#27
The tender is supposed to be connected to the terminals under the hood. For some reason, the battery won't charge properly if the tender is connected directly to it (this is according to my S.A.)
#28
My Ride: 08 550 Carbon Sport Almost everything factory, but no sound upgrades.
Ask the S.A. what "charge properly" means. I think he is stretching your chain.
sixcard
#29
My Ride: E61 545i Sport Touring
#30
My Ride: 535i 6-speed
I've been using a Deltran Battery Tender Plus on my '08 535i for about a year now. I have the Deltran cable connected to the (+) and (-) terminal points under the hood and the other end is the tender connector. So I have it connected with the hood closed. I have had no problems at all.
