I need to do the following on my 04-E60:
1) Turn my DRL's off 2) Register AGM battery 3) Turn on CPT9000, the dealer replaced my idrive when it died over a year ago, and they didn't turn on my CPT9000, I have a BTUM, that I want to be able to use that plugs in directly into the CPT9000 to use the bluetooth features. 4) Install a CD Changer that I recently bought off a member. Question to the wizards who have experience with the above, 1) Should I get a software scanner tool and do the above myself? I am more inclined to go this way since I have 2 E60's. If yes, which one do you recommend, without breaking the bank? Here is one - the professional version... http://www.bavariantechnic.com/buy.aspx Thoughts and thanks in advance! Sonny |
Originally Posted by stock545i
(Post 1256333)
1) Turn my DRL's off 2) Register AGM battery 3) Turn on CPT9000, the dealer replaced my idrive when it died over a year ago, and they didn't turn on my CPT9000, I have a BTUM, that I want to be able to use that plugs in directly into the CPT9000 to use the bluetooth features. 4) Install a CD Changer that I recently bought off a member. Question to the wizards who have experience with the above, 1) Should I get a software scanner tool and do the above myself? I am more inclined to go this way since I have 2 E60's. If yes, which one do you recommend, without breaking the bank? Here is one - the professional version... http://www.bavariant...ic.com/buy.aspx Thoughts and thanks in advance! Sonny |
I have a (dumb, maybe) question about this. Could you use it to activate for example aux or ipod input on a non-aux input car? Or is that only dealer business?
| All times are GMT -8. The time now is 04:26 AM. |
