Is there a DIY on removing a 2004 530i stock air filter box?
My Ride: 2004 e60 M5 Replica
Titanium Silver
Premium Package
Premium Sound Package
Adaptive Xenon's
Apple iPhone cell interactive pared with iDrive Bluetooth setting
19 inch BMW OEM 166M rims,
Michelin tires
Sprint Booster - V2
Fidelity / BMW Extended Warranty 7 year / 100,000 miles
Dear 5 series Forum members,
How a difficult is it to remove a 2004 530i air filter box?
Is there instructions here at the forum what's all involved, and the steps how to remove it by a BMW owner, or should it be done by an BMW mechanic?
Thanks in advance!!
Eddie aka Presley348
Thanks in advance!!
Very easy. There should be a DIY here. I think I've seen one in the past. I'll give you a DIY verbally tho....
Open the hood.
Looks for the MAFS. Unclip the sensor's cabling.
Unscrew the metal retaining band until it's loose.
Now, look for the two bolts that hold the airbox down and unscrew those.
You should now be able to pull the airbox out of its resting place and also away from its main intake hose.
Now that you've read this, determine what size starbits you'll need because I dont remember off hand. And decide what to do with the MAFS because it's attached to your airbox. There will be two screws holding it in. obviously you need that part if you're putting on a non-OEM or modified box....so you'll need to figure out where it fits in the equation.
Good luck.
Open the hood.
Good luck.
socale39
09-05-2023 08:30 AM
Mihainede85
03-11-2015 09:45 PM
