Tarnished Chrome Grill
My Ride: 520D
Hi,
I'm attaching pic of irregular tarnishing on chrome part of front grille. I thought it was removable grit until I tried to remove it earlier to-day when I discovered that it was discoloration or tarnishing. I would like an opinion on what might have caused this (is it real chrome or chromium-plated plastic?) and what I should do now since the car is only six months old.
NB. The car was not subject to any abrasive chemicals. All advice welcome.
Many Thanks
Many Thanks
![Tarnished Chrome Grill-img_0661.jpg](https://5series.net/forums/attachments/e60-discussion-2/44346d1482365851t-tarnished-chrome-grill-img_0661.jpg)
Was it subject to salt on the roads from the winter? Salt can corrode chrome plated surfaces, as well as others. My chrome license plate frame gets corroded every year, and it looks just like your grille. I just replace it in the Spring for $5. However, my front grille hasn't had any issues...would hope it's better quality than my $5 frame. I do keep the grille clean, though, from all salt during the winter, just in case.
Either way, I would take it up with BMW. I am sure they would replace it if your car is only 6 mo. old.
P.S. Please update your location.
You say it was not subjected to abrasive chemicals, but by that do you mean while cleaning? As DrLev said, road salt can cause such damage. Alternatively, is it possible that something splashed on the chrome while you were driving, either from a vehicle you were following or some caustic chemical already spilled on the roadway? The pattern of the spotting makes it look like a corrosive liquid was splashed on it somehow. I would think if it were faulty chrome the pattern would be more uniform. But, as suggested, it's always a good idea to see what BMW says. If defective plating is the culprit, I'm sure they'll replace it, especially on such a new car. Good luck.
Actually,
On my very first e60(04) I experienced the same. The one thing I remember is: I washed my car in the winter and the next day i saw those marks.
Vman33
03-14-2022 04:43 AM
viper1213
10-26-2015 08:50 AM
umichchris
09-10-2015 12:54 PM
umnitza
09-02-2015 11:28 AM
