Tailights Out
My Ride: 2005 530i
Model Year: 2005
Engine: M54
Our left rear indicator went out a few days ago and when I went to replace it I learned that the entire rear left lighting unit is out. No brake lights, not turn signal, no driving lights. Any advice about what to check would be much appreciated. I haven't looked at any fuses yet but can do that later today.
TIA
TIA
What year is your car? Sounds like it could be the tail light recall problem. BMW used too small a ground to the tail light assembly and in some cars it has melted plastic and insulation.
Here's one document:
http://www-odi.nhtsa.dot.gov/acms/cs...3V407-5690.pdf
You can Search on this site and find more on this. BMW came out with an improved tail light assembly that has an extra ground that is to be attached to the ground harness located under the tail light.
very common on our cars its the ground cable if you pull out the bulb holder you will see its kind of melted or burned it needs to be replaced with new socket new tailight bulb holder and i would also replace the ground able
memerchan
06-05-2012 08:01 AM
supac
05-28-2008 12:24 PM
