5Series.net - Forums
-   -   Switching out a blown MPM module (https://5series.net/forums/e60-discussion-2/switching-out-blown-mpm-module-153084/)
rkaen Mar 6, 2023 03:46 AM
Good day everyone,
i’ve been looking for a used mpm module, but I can’t seem to find one with the exact number. Do everything need to be the same or what?
https://cimg7.ibsrv.net/gimg/5series...321e1aab4.jpeg
seanjordan20 Mar 12, 2023 10:26 AM
Originally Posted by gman6262
Look up the part number in Realoem - that will give you the other part numbers for that module. The module needs the correct firmware for your build - which means you need to be careful with the application dates on the alternative numbers. You won't be able to use an older module than your build.
https://www.realoem.com/bmw/enUS/par...&q=61356939655
I thought MPMs were plug and play. The years do not matter. As long as it's one on the link you posted it will work. I've never had an issue at least.
