swirl flap removal
just got the swirl flaps removed in my 05 520d and i do remember reading a really long thread on the forums and its supposed to have no adverse effect on the car, in fact its supposed to make it smoother.
different experience here i must say.
the car is really sluggish now and in low gears/low revs it barely accelerates. the car is remapped too so it seems like all the remap bonus is gone, that nice torque "pull" is all but gone. the car drives worse than before i did the remap and remove the flaps![Frown](https://5series.net/forums/images/smilies/imported/sad.gif)
no idea whats going on. someone else experience this? MAF sensor?
Model Year: 2015
Engine: N55
Don't see how removing the swirl flaps would do this as later cars were produced without them.
Almost sounds like a turbo malfunction.
well the swirl flaps shouldnt affect it at all. the car was a bit like that before removing them anyway. is just that now you can feel it more.
the turbo works fine in higher gears/revs. i had a mechanic check the turbo parameters while driving and the computer showed its fine, but the MAF reading was fluctuating which is why i'm thinking its that. havent got a chance to remove it and clean it to see if it makes a difference.
do the e60s diesel have a limiter on the turbo on the likes of 1st and 2nd gear? according to specs should kick in at 1750 rpms.
Any error codes?
My Ride: Bmw 530d 2004
Sorry to hear, but I'm 100% sure it's not because of the removal of swirl flaps. It is something else. Unplug and replug all electric harnesses, check the charged air tubing etc.
I hope you get it solved.
- Antti -
ps. The long thread you're talking about locates on a DIY section.
- Antti -
My Ride: 2005 530d auto ,Carbon black,all options but HUD and sunroof
As Antti says check and recheck all connections, vacum lines and electrical s.
I was distracted by tel/call during final assembly, then started the engine to my horror , engine light was on. After rechecking,I found the quick release clip on EGR was not in place. connecting it cured the problem. I have had the emission measured before and after removal and there is hardly any difference, performance is as strong as before.
Good luck
Good luck
ok so that was done by a mechanic who has done lots of these before so i know (hope) he didnt do anything wrong. he was saying he found a bit of oil in the EGR and he cleaned it. we will try the MAF tomorrow and see. no error codes show up but then again the MAF doesnt always show errors so hopefully its just that.
another thing i've noticed literally right after the flaps were taken out is that the car doesnt mind as much if for example you're in 5th gear and doing 80km which it didnt like before. and also now its really hard to even get to 3000 rpm in 4th 5th or 6th gear! before it was going up real fast if you floor it, can still feel the turbo kicking in tho. is that normal?
- Antti -
My Ride: 2006 520d - 19" 172s- Remapped - LCI taillights V6 cables - LCI xenon headlights - Denison 500 with BTA1500 - led interior lights - OEM led number plate lights
Planned mods:
Folding mirrors - Modmynav kit - High gloss shadowline trim -
PelicanParts.com
07-09-2015 01:07 PM
