Swing support question
My Ride: 2009 535xi
2009 535i x drive noticed that my right front swing support rubber boot has split .I have located the correct parts and was curious if anyone can point me towards a DIY for this ?.. Seems pretty easy only concern is on the X drive model i know things can be slightly different that a 535i.. if anyone can can share any insight on this it would be greatly appreciated.
Thank you in advance!!!
Do you mean the CV joint boot? Do you know how long it has been split? Unless you know it just happened, it got some contamination. In other cars I have had, I just replaced the entire half shaft.
My Ride: 530i
Engine: M54
'swing support' is the sway bar end link, at least that's what BMW calls it.
There really isn't much to replacing them. jack the car up using a floor jack at the jack point, remove wheel, remove worn end link and bolt in the replacement. you'll need to place a torx bit on a ratchet into the end of the threaded portion of the sway bar link to hold it in place, and loosen the securing nut with a wrench. Should take about 10 minutes per side.
My Ride: 2009 535xi
Nice , just picked up the parts also looks like i can silde a thin "cone " wrench or bike wrnch 16mm-18mm to hold it in place whlie i turn the nut on the other end
