suspension problem
Old Oct 20, 2008 | 01:29 PM
monsterj34's Avatar
ok...
here is the situation....
i had suspension issue whenever weather is cold and this thing doesnt happen during summer time.
now it is getting cold and issue with suspension is back.........
Whenever i go over speedbump , i hear my car making sound like a old mattress with old spring..
does anyone haveing problem like this?
Old Oct 20, 2008 | 01:48 PM
hondik's Avatar
My Ride: E61 CarbonBlack 535d, Ventilated and Heated Comfort Seats with Massage in Black Nasca Leather, Dark Poplar Wood, Professional Navi, Folding Rear Seats, Load Through, Advanced Remote, PDC, Bluetooth, Dimming and folding Mirrors, Bi-Xenons, Hi-Fi, Tinted
Oh yeah - 70's porn movie bed - just go to your dealer and have them replace rubbers down there
Old Oct 20, 2008 | 09:48 PM
Angelic0-'s Avatar
here, the dealership... amongst the local BMW workshop.... call it the squeegie brushing...
Old Oct 21, 2008 | 01:37 AM
fraseman999's Avatar
Hi,
My e60 has seen it all now done 168,000 miles. Your problem is lower ball joint. In the uk i prefer to call it a bush. Not one for the diy cause its on the lower rear knuckle and a big long bolt goes through it. The difficult part of the job is pressing the bush out of the knuckle. My mechanic made something to do it with. I had both mines done within a 4 week period. It starts as a squeak then if you jack the back up you will have some play in the wheel. With the correct equipment job takes about an hour a side.
Yep, just checked the ksd timings disk job is: Ball joint in rear knuckle wheel carrier 33 32 125. Timings allowed 60minutes. So if you take it to the dealer should only be charging you 1 hour per side plus part. Over here 1 ball joint cost about ?30.
Same bush is on the e39. So if you dont want to fix it now here is a tip. Put a pin hole in the rubber and spray it with wd40. Sqeaking will go. This is only a quick fix and is good if you cannot get it fixed for a couple of weeks.
Need any more info let me know.
Cheers
Old Oct 22, 2008 | 10:57 PM
pinguhk's Avatar
My Ride: Mini Cooper
Originally Posted by monsterj34' post='698246' date='Oct 21 2008, 05:29 AM
ok...
does anyone having problem like this?
I change my lower arm on both side at 40000km.
it is very common for this to brake. The rubber inside always crack about 40000km to 50000km
alot of HK members have also change there.
I hear that a 3rd party company has started to make them and sell them which is half the price of BMW 1s.
other thing is it mite be the rubber holding the sway bar that is old and cracked
Attached Thumbnails suspension problem-002_09_fixing_3_rubber_in_bars_and_steel_brake_lines.jpg   suspension problem-003_09_fixing_3_rubber_in_bars_and_steel_brake_lines.jpg   suspension problem-005_09_fixing_3_rubber_in_bars_and_steel_brake_lines.jpg   suspension problem-007_09_fixing_3_rubber_in_bars_and_steel_brake_lines.jpg
Old Oct 22, 2008 | 11:23 PM
Bimmer530I's Avatar
I have the same issue. Will take it to the dealer and have them check the car out.
Old Oct 22, 2008 | 11:26 PM
Bimmer530I's Avatar
Pingu, how much did yu have to pay to get them replaced?
Old Oct 22, 2008 | 11:33 PM
pinguhk's Avatar
for each it cost me about $350us each
Old Oct 24, 2008 | 02:12 PM
These are not the ones i am talking about these look like fronts.
Old Oct 24, 2008 | 02:53 PM
DrLev99's Avatar
Originally Posted by fraseman999' post='698670' date='Oct 21 2008, 05:37 AM
The difficult part of the job is pressing the bush out of the knuckle. It starts as a squeak then if you jack the back up you will have some play in the wheel. Put a pin hole in the rubber and spray it with wd40. Squeaking will go away.
I tried this with my girl last week....worked like a charm.
