Suspension noise when turning steering wheel
Old 06-15-2012, 03:00 AM
bmwbimmer's Avatar
My Ride: Bmw e60 530i _-_ professional navigation- mystic blue exterior- beige interior-logic7-18 inch rims-active steering-bluetooth-adaptive xenon lights-sunroof-sport steering wheel-comfort seats-tv-pdc
It happens only when I'm at a standstill and the brakes applied if I turn the wheel all the way left or right I hear noise from the suspension like something is being pulled, it doesn't happen when the brakes are not fully applied and it only happens on a standstill. I was told its normal, this happened after I changed my lower control arm's in the dealer, they told me it because ur control arms are new and the front struts need to be replaced but could that be the reason.
Old 11-02-2012, 02:28 PM
bmwbimmer's Avatar
Front struts were replaced but still the vibration is still there, it only happens ata a stand still and when I have my foot on the brakes and steer left or right the steering shakes and their is noise. Any help would be apprieciated
Old 11-02-2012, 02:44 PM
scb88's Avatar
My Ride: 07 550i, Sports Package, Logic 7, Manual Trans.07 Toyota Tundra CrewMax 4x4; 09 HD CVO Ultra Classic Electra Glide
I have a similiar issue, slow speed, full turn left or right, "Pop!" from the front end. New control arm bushings, still happens. Otherwise all is good. Not sure what it is.
Old 11-02-2012, 07:05 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
i had a slight clunk noise in front end also after installing new struts. ended up finding that when the mechanic removed the control arm bolt to get strut out, he didnt tighten the control arm bushing bolt enough. the bolt looked tight, but the control arm bushing was still able to shift a bit on the bolt, causing a clunking type noise, when turning the wheel while stopped. the control arm bushing bolts need to be very tight.
Old 11-03-2012, 05:03 AM
bmwbimmer's Avatar
I had the noise even before I replaced my struts, it maybe something with the ps.
Before I replaced my control arms I didn't have any of these issues, but now if I'm at a standstill and I steer lock to lock only when when my foot is on the brake the steering shakes and I can hear a noise like something is pulling I hope we get this issue solved.
Old 11-03-2012, 12:53 PM
white535xi's Avatar
check your steering fluid. that was that issue on my car
Old 11-05-2012, 08:30 AM
bmwbimmer's Avatar
So you had the same exact issue you solved it by replacing the power steering fluid ?
Old 11-05-2012, 08:48 AM
bmwbimmer's Avatar
I checked the power steering fluid its full.
Old 11-05-2012, 10:08 AM
turboawd's Avatar
worn engine mount?
Old 11-06-2012, 07:57 AM
bmwbimmer's Avatar
I think it has something to do with the control arms I replaced becuase since I replaced them the noise developed, I tried to find the source of the noise I saw that it was coming from the pipes but all are ok. And when I steer either left ot right you can see the wheels vibrating slightly while moving.
Quick Reply: Suspension noise when turning steering wheel
