Sunshade and power seats not functioning.
My Ride: 2005 BMW 545i 6spd and 2000 Lexus GS300
Hey fellas, so I'm a noob and I have a 2005 545i manual. I installed this sport mode thing into the car (it didn't work for me). After I accidentally shorted the climate control my AC wasn't working. I replaced the fuse and the AC now works. But NOW my power seats and rear sunshade doesn't work. Windows work but those two things aren't working. I checked the fuse but they are fine. If you guys can give me your 2 cents on what the problem would be that would be awesome. Again I know I'll receive ridicule but hey I'm a noob lol what can you expect? THANKS!
It took my ac control unit and every off and that caused the issue. I simply checked for blown fuses and if all is good i took the whole center dash apart and replugged everything and it worked. Good luck man
I finally also sorted out the problem, after taking the dash apart 5 times, I worked out that the plug that connects behind the PDC button needs to be pushed completely into the socket.
Still have a left fog light error to resolve, as I know there is nothing wrong with the bulb as I tested it on the right hand side.
This also appeared after I took the dash apart.
Wanted to add that the plug that connects to the PDC, appears control the following functions. If not inserted correctly
Left & Right Comfort Seats
Steering Wheel tilt & extension
Rear sunshade
Left & Right vanity lights
Active Steering
Rear sunshade
Active Steering
socale39
Sep 5, 2023 08:30 AM
zio
Jun 18, 2015 04:42 PM
