Sunroof Won't Close after the engine is off, and
The manual states that after the ignition is turned off and the key is in position 1, I can operate(open/close) the sunroof for approx. 15 min provided that I dont open the front driver door. And it also states that after the ignition is turned off and the key is in position 0 or removed, I can operate(open/close) the sunroof for approx. 1 min provided that I dont open the front driver door.
My car doesn't do that. Once the Engine is off the sunroof stops working, I can't open/close/tilt it. If you turn the key to position 2, which is the one right before the ignition starts, it works just fine.
The sunroof itself works great with no problem for what it does. The windows work just fine in position 1.
I can open it from outside if I press and hold the open button on the key fob as well as the windows.
Does anyone have this problem or know how to fix it.
Thanks
Thanks
rackhacker9275
26
04-16-2015 08:13 AM
